#11 |
Liked 128 Times in 50 Posts
It took a little effort to get them in. I figured it would wear down once I got some time on them but it still continues to drag after 2 seasons now. Though I haven't been racing much over the last couple of years.
Bobby Lundholm 3516 G/SA |
#12 |
Liked 33 Times in 16 Posts
One thing you might try is loosen the m/c from the firewall to see if the rod is fully retracting...with the fronts off the floor you can spin the wheels to see if there is any improvement. Using an aftermarket m/c and/or a lengthened brake rod? I recently had to remove the front pads on my partner's '66 Nova and take a DA sander with 80 grit to them to alleviate the same problem.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 04-08-2014 at 10:07 AM. |
#13 | |
Stock master cylinder.
#14 |
Take them off and grind them down a little. Costs nothing to try and it worked for my buddy's Nova.
Rich Taylor I/SA - 321 |
#15 |
Liked 19 Times in 7 Posts
Small GM transmission spring in between the pads held in with the willwood cotter pin. No more drag
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
#16 |
Liked 427 Times in 97 Posts
For those not wanting to use a Mopar Master Cylinder, NAPA part number M2456 is a "Lightweight" Master cylinder that is a bolt in replacement for the heavier cast iron version.
http://www.napaonline.com/Catalog/Ca...456_0358745370 |
#17 | |
