Old 04-09-2014, 09:45 AM   #1
boostedf22c
boostedf22c's Avatar
Default Best solution for fogged up visor/glasses
What tricks have you guys used to help prevent fogging of the visor/glasses. I have to wear glasses, otherwise I can't see…haha. During the day it's usually fine, but if I have to make any late afternoon, early evening passes it seems like I have a lot of trouble keeping the fog down. So much to the point of having to make a run with the visor up and my glasses off. Which isn't safe as I can't see anything, and I run methanol so I would rather have the visor down to save my eyes in case of a fire. I wear a head sock that covers my mouth and that seemed to help a bit, but not enough.
Any info would be appreciated.
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 04-09-2014, 09:53 AM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Best solution for fogged up visor/glasses
PJ1 sells a product called Fog Blocker thats specifically made to prevent fogging of shields, visors, etc.
Jim Kaekel 3836 STK
Old 04-09-2014, 11:05 AM   #3
west coast
Liked 223 Times in 73 Posts
Kleer Vue is what i have used for about 10 years now works great, I usally do it every morning at the races. I got it first at the auto shows but you can buy it direct.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 04-09-2014, 11:54 AM   #4
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Carey,
The old F-1 racers used to drill some holes in the visor for ventilation, or use small pieces of tape to keep the visor up just a tad for air...The new contact lenses are pretty good even for astigmatism, and for the military grade solution, you can do the prefered method of the armed forces, Lasik. I am also sure that they make prescription visors which would solve your issue, but at a $ cost and likely effect your view(distorted)
Eric
Eric Merryfield 1883 STK
Old 04-09-2014, 01:23 PM   #5
FED 387
Liked 333 Times in 180 Posts
Fogtech DX!!!!
Old 04-09-2014, 01:40 PM   #6
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Just grab some bar soap, smear a little on each side and buff it out. Works well and its free.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 04-09-2014, 01:46 PM   #7
FED 387
Baby shampoo works well too
Old 04-09-2014, 09:03 PM   #8
nickh
nickh's Avatar
Liked 653 Times in 195 Posts
regular shaving cream works also.
Old 04-09-2014, 11:37 PM   #9
JoryE
JoryE's Avatar
A little trick I learned from an old funny car guy, aka my dad, is duct tape across the nose to cover the opening between your mouth/nose and the visor. Works like a charm and its pretty darn cost effective.
Jory Elliott
Northern Force Racing
SS/AM 155
JoryE is offline   Reply With Quote
Old 04-10-2014, 01:46 AM   #10
Chris Williams
Chris Williams's Avatar
RainX works for me.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
