Old 04-13-2014, 03:20 PM   #11
Chad Rhodes
Default Re: TH200 issue
Originally Posted by Alan Roehrich View Post
A stator shaft problem should show up on a data logger in a very obvious manner. The starting line RPM should be substantially lower, at least 2000 RPM lower than a previous "good pass". When the stator shaft spins, the converter will not flash, and it will not multiply torque.
With clutches, or the "sprag", RPM should be slightly higher, but driveshaft RPM should be lower.
The Converter flash seemed a little high as well now that I look at the data, it also ran within .3 mph of what it had all day. I'll have it out this week
Chad Rhodes 2113 I/SA
Old 04-13-2014, 05:56 PM   #12
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
i agree with Billy, broken stator support, did the same thing back in 09 with my 305 k/sa camaro
jim powers is offline   Reply With Quote
Old 04-13-2014, 07:16 PM   #13
Gary Parker
Liked 425 Times in 56 Posts
I have broken 2 stator supports. some are now changing them with a heavier one I believe adapting a turbo 350 one... that's what it sounds like to me
Gary Parker 1617 STK
Gary Parker is online now   Reply With Quote
Old 04-13-2014, 08:14 PM   #14
Billy, that should stop the converter from reaching full stall speed or flash stall speed. Normally. It's a common problem with big engines, but I don't see it too often with small blocks, especially in Stock.
As stated, it won't stall up with stator free wheeling..It'll just act like a stock converter almost.
The low sprag is the weak spot alright.
You need to find out if the lo/rev clutches are on or off with your valve body.
If off ,and just the forward clutch on, I'm going with the sprag slipping..
Probably find broken springs and distortion on some kind...
Old 04-13-2014, 08:23 PM   #15
Chad Rhodes
It's a turbo action e shift if anyone knows the answer before I call tomorrow.
Old 04-13-2014, 08:34 PM   #16
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
If you have engine breaking in 1st gear, then the clutches are on.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 04-13-2014, 08:40 PM   #17
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Broken stator support.
Happened to our 200 yesterday at Bowling Green...
Rich Taylor
I/SA - 321
Old 04-13-2014, 08:42 PM   #18
Chad Rhodes
No engine braking in first.
If the stator support broke would it damage the converter ?
Old 04-13-2014, 08:46 PM   #19
HandOverFist
I don't know that answer either. Just to be safe I'm going to let ATI cut it open for a look on ours.
Rich Taylor
I/SA - 321
Old 04-13-2014, 08:50 PM   #20
Dean Feiock
Then your clutches are not on. Very few use the clutches as they are faster without the clutches on.
Even if the converter doesn't get damaged, it will be full of debris. Needs to come apart either way.
