Hi, new to forum and was curious. I have a '63 Ford Fairlane that I was considering running in stock eliminator. Was available with a 260 or 289 Hipo . Both with 4 speed. 260 would put it in T/S and 289 in H/S. Was kinda interested in the 260 combo just because it seems so off the wall. Is this a viable combo? If I run the 289 combo will I need '63 specific block and heads because those are impossible to find. Been a bracket racer for many years and ready to do something different.
Liked 2 Times in 2 Posts
I have a 63 falcon sprint with the 260 that my dad bought new in 63. The problem with the 260 is the hp rating of 164. Nhra has reduced it to 158. It needs to be at 138. IHRA has reduced it to 145. The 63 260 has smaller valves than the 64, but has the same hp rating. With the 289, I am not sure if you have to run the 5 bolt block or not. I think ihra has reduced the 289 hipo rating for pure stock. You might want to contact Alex Denysenko, I think he was the one who got ihra to defactor the 289.
I'd thought about the smaller valves in the '63 260 heads. 5 bolt block would probably be a deal killer. Very hard to find even as a standard 289 let alone a Hipo.
Liked 4 Times in 1 Post
If you already have a 63 Fairlane, go with the 289/271 motor, but if you a haven't gotten that 63 yet, let me suggest a 65 Fairlane, Mustang or Comet. With either, you can run 3 different 289 motors, 1 2 bbl or 2 4 bbl combo. If NHRA requires the correct block, ie 5 or 6 bolt, 65 combos will keep you safe with 6 bolts, but I don't think they care which you use for stock. I think there is a 64 hipo Fairlane running on the West Coast, so that combo is doable as a 63. Unless you're running IHRA, a stick combo only.
#5 | |
Liked 237 Times in 126 Posts
I wanted to start in Stock and build up to SS, but finding parts was such a hassle that I went for GT just to be able to use good stuff and stay in the rules. That stocker I wanted to start with was a 66 Fairlane. Great car, but real hard to find one clean enough to run in Stock without years of work. They are either rust buckets or street rods. Dale
Already have the '63 that's why I started the thread. Response is what I pretty much suspected. Probably just continue to bracket race and build it however I want. Crazy how a car like this isn't really a good option but a turd 305 Camaro, a POS Mustang II, or a powerhouse Chrysler K car is. Thanks for your replies.
#7 | |
Dale
#8 | |
#9 | |
Dale
#10 | |
Liked 166 Times in 54 Posts
I can answer that question for ya.....uummm no you cant cut the shock towers back. ..been asking for that for years!!
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
