Old 04-29-2014, 08:50 AM   #11
Greg Reimer 7376
Liked 719 Times in 220 Posts
Default Re: headers glowing red
Originally Posted by henrys57wagon View Post
Thanks again guys As far as the primary throttle plates go what size hole do you have/ recommend, ours are 1 in each primary plate and 1/8" dia?
The throttle plates are well past the idle slots and am wondering if I should drill another hole in each primary plate to get the plates back to where they allow the idle circuit to work? Or keep increasing the size of the one hole?
We are still running the front metering rods. The car will be mainly a street car. We have kept our 69 Stocker engine but with a 2800 stall and only a 373 street gear in it now, but LOVE how the engine performs on the street
Sounds like a 1/8" air bleed hole through the primary throttle butterfly is about right. if you have the proper static initial timing, the engine's idle characteristics would improve to where no further mods were necessary.
Old 04-29-2014, 12:36 PM   #12
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
piston at TDC - ON THE COMPRESSION STROKE, I know you have probally checked this. I had this happen to me 1 time, engine ran but headers got cherry hot. I was in a hurry and had the distributor on TDC #1 set on the wrong stroke.
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 04-30-2014, 03:53 PM   #13
Jody Lang
Liked 92 Times in 29 Posts
I don't think you can get away with that much timing with that low of a stall. Breaking motor in with that much timing wont be a problem. Driving on the street I think it would detonate.
With the primary rods in it (which is fine) with no load on engine the rods are down in the lean or big part of the rod. Just not enough fuel is getting past the rod/jet for the raised RPM.
As a quick fix when breaking cams in I've just ran some duck tape across the choke area to richen it up. Cherry red exhaust will be gone. Don't forget to remove duck tape after break in.
Jody Lang is offline   Reply With Quote
Old 05-04-2014, 09:01 AM   #14
henrys57wagon
henrys57wagon's Avatar
Thanks again guys.
We finally got back to the Nova. I took the carb apart at home and cleaned/ blew it all out. We put the carb on and set the timing to 36# at 3000. The headers glowed so we put the old HEI back in ran it up and set the timing to 36 and the header glowed!!!!
We took the carb off and went to put the spare on but were missing a plug for this carb so I said lets put the 1st carb back on and see what happens.
Well low and behold everything worked fine??????????
So with the throttle plates drilled with a 1/8" hole the plate is above the idle slots and idling at 1100 in neutral, dropping to about 800 in gear.
What if we drill another 1/16 hole in each plate or would you recommend opening up the 1/8 hole to 3/16?
Thanks, Henry.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 05-04-2014, 10:24 AM   #15
Liked 1,927 Times in 433 Posts
I'm not sure you should need a 3/16" hole in the throttle blades to get it to idle.
Old 05-05-2014, 12:25 AM   #16
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Not trying to contradict anybody, & mine doesn't have a q-jet but to get my 351C with a 2bbl Motorcraft to idle decent, I currently have a 1/4" hole in each throttle plate. & it adjust's correctly now. But my cam is probably too big.
Dave Noll, EF/S ,?/SA 6526
Old 05-05-2014, 06:04 PM   #17
henrys57wagon
I am going to drill another smaller hole in each plate and see what happens. I have lots of spare plates so if I go too big I will change them.
Old 05-05-2014, 09:58 PM   #18
Dave Noll
Dave Noll's Avatar
That was my justification for experimenting that far out of the box.
