Old 04-29-2014, 09:42 PM   #1
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Default New Clevite (mahle) H series brgs look terrible ??
This is the first time I have ordered 'H' series Clevite bearings. Previously only used the P series, or King Alecular. These Mahle Clevite H series bearings have extreme discoloration and a strange pattern to the babbit I have never seen before. The backings are also purple and blued as in what I suspect is evidence of high temperatures during the manufacturing process.
Perhaps this is all a result of the different babbit alloy that the H series uses, needing a higher temperature to braze to the backing.... But it also almost looks like they were exposed to some sort of corrosive atmosphere which attacked the babbit ???? They really look quite terrible, and I would think they would include a little statement about that in the box if that is normal ???
Sorry if this has been asked before.. I tried searching the forum to no avail, and the Clevite (Mahle) website is now beyond painful to navigate..
Old 04-29-2014, 10:36 PM   #2
John Dinkel
Liked 265 Times in 69 Posts
Thumbs up Re: New Clevite (mahle) H series brgs look terrible ??
They are ok .
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 04-29-2014, 10:37 PM   #3
Liked 1,927 Times in 433 Posts
Default Re: New Clevite (mahle) H series brgs look terrible ??
The H series bearings do not have the same over lay as the P series, they look dark and stained. That's normal.
The rod bearings are narrowed, not chamfered.
Old 04-29-2014, 11:01 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I have those. They aren't plated so they aren't very pretty. That's all. The thrust bearing should be one piece with no welding, which makes it nice and strong. Kind of the Ugly Betty of the bearing world.
Dale
Dale Shearon
68 Mustang 6394
Old 04-30-2014, 08:08 AM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
In case you don't know rod bearings have upper and lowers,uppers have U,lowers have L
uppers go in rod and lowers go in cap,they are narrowed to clear radius on crank
Mike Taylor 3601
Old 04-30-2014, 10:50 PM   #6
Kevin Panzino
Ok gents, good to hear. Thank you for the prompt info.
Kevin
Old 05-05-2014, 03:45 AM   #7
draginmopars
draginmopars is offline   Reply With Quote
