Old 03-12-2014, 08:21 PM   #21
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Default Re: Mustang 5.0 Stocker brake pressure
Originally Posted by Bobby Fazio View Post
I got the UPR race products manual kit but can't hold the car on the line past 2000 rpms. I bought some good brake pads for the front and still use drums in the back. Not helping and this is a 5000+ stall converter. My old 3000 stall used to hold at 2200 no problem (with power booster). I bled the system and have a very good pedal. Auto, not a stick.
I plan to put a pressure gauge on this week, how many pounds should I be looking for? Could new master cylinder be the culprit?
my little 5 foot 1 inch beautiful bride Beth pumps hers up to 800 psi on the starting line before engaging the two step and that's with her itty bitty size 6 feet
bobby we have some much better pads for you. same as what we put on Beth's car
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 03-13-2014, 12:40 PM   #22
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
600lb up front after pumping the hell out of it. Gonna try smaller master cylinder before I start trying to take this brake pedal apart.
'65 Mustang SS/L & L/SA
Old 03-13-2014, 09:11 PM   #23
fordteacherguy
Liked 160 Times in 51 Posts
Bobby,
I used maximum motorsports manual brake conversion kit ($199 List price) with all stock components on my Super Stocker, brakes just fine and I foot brake it too sometimes. Brake pressures (just went out to garage to check) easy push on pedal 600-800 psi, med push 1200-1400 big push 1700psi+. I love the quality of the components and Its a nice textured pedal.
Here's a link below. I syringe bleed the master backward to remove all air. Stock front t brakes, 10" ranger rears.
http://www.maximummotorsports.com/Mu...ions-C244.aspx
fordteacherguy is offline   Reply With Quote
Old 03-17-2014, 08:19 AM   #24
Bobby Fazio
Ok thank you for the tip. Getting the brake pedal out was a nightmare so I stopped and put it back in and decided to get a Ford Ranger master cylinder to see if that can get me to at least 800psi. If that doesn't work then I will look into that new pedal kit from MMS.
Old 04-30-2014, 10:43 AM   #25
Bobby Fazio
Ok got the car running again and installed the MMS brake pedal kit with better ratio so I can hold around 2300rpms on the line as opposed to the 1800 before. This is with the '86 ranger master cylinder. When I try the two step any higher than 2300 it creeps through the beam. My lights suck and I have 20lbs of air in the bias ply slicks. Need to raise launch rpm to reel the RT in. Turning 1.60-1.62 sixty foot times when not creeping. In order to hold better on the line, should I upgrade the back to a disc setup from the drum setup or should I upgrade the front to a bigger/better disc setup than the current stock configuration?
Old 04-30-2014, 02:13 PM   #26
Chris1529
Liked 70 Times in 29 Posts
How low is the first gear in your trans and what about rear-end ratio?
A really low first gear ratio can cause the lower stall rpm.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-02-2014, 02:07 PM   #27
Bobby Fazio
2.92 and 4.88 with 28" goodyear slick
Old 05-03-2014, 12:28 AM   #28
fordteacherguy
Bobby,
I have stock 89 brakes in front and 10" ranger brakes in the rear. Works great w/footbrake with that MM manual brake kit and stock master.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
