#31 |
Liked 2 Times in 2 Posts
Don't give up!!!! Put that thing back together and run it on 7 cylinders. I've seen you do more drastic things than that!!!
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#32 |
Liked 317 Times in 108 Posts
Phil,
Probaly dial the same on 7 or 8 cylinders LOL Mike Taylor 3601 |
#33 |
Liked 240 Times in 112 Posts
Just a thought. The PCV isn't hooked to a vac. port on that runner is it ?
Dave Noll, EF/S ,?/SA 6526 |
#34 |
That picture on my phone looks more rich than oil.
Ed Wright 4156 SS/JA |
#35 |
I got rained out today so i decided to do some more work. I glued the crap out of intake and put it back like it was. i fired it and was pretty much the same. I loosened the rockers ran it withem loose for a few and then adjusted on them while running. Somehow someway My cylinders are burning the plug looks great now. I beat it up and down the road for a bit and seemed to be running good.
#36 |
Where's the "Hell Yeah" button?
#37 |
Liked 805 Times in 341 Posts
#38 | |
Gary Burr IHRA MEMBER # 1958 Stk 1949 |
#39 |
Liked 719 Times in 220 Posts
So, what did you find? How did you have such a great cylinder leakage percentage with a valve hanging open? Was the lifter bottomed out to the point where the valve only closed with room temperature non-expanded parts,( i.e valve stem and pushrod) and was held off its seat when things hit operating temperature? If loosening the lash did this, that must have been the case. Hope your concrete project turns out as nice.
#40 |
Liked 44 Times in 19 Posts
Good Luck, Phil! I'll try and look you up tomorrow.
Marty Knox 3071 STK |
