Old 04-23-2007, 07:49 PM   #91
ForbesMotorSports
Default
spec button
ForbesMotorSports is offline   Reply With Quote
Old 04-23-2007, 08:27 PM   #92
SSDiv6
Liked 1,583 Times in 582 Posts
Default
Who would control the such "Spec Button"???? Be real!!! Racers have a lot of ingenuity!!! Just do away with all the electronics and special buttons and bring back the good 'ol fun days!!!!
Old 04-24-2007, 09:21 AM   #93
Stan Perry
Default
OK then what's next,,,,,,,,,,,,,,, A SPEC DELAY BOX,,,,,,,,, I just don't think NHRA is understanding the CAN OF WORMS they are opening just by thinking about delay boxes in Comp and S/S....There is so much other stuff along with the box ,,,,,,,,,,,,it is unreal what electronics can do. Just my 2 cents worth..
Stan Perry
Stan Perry is offline   Reply With Quote
Old 04-24-2007, 09:44 AM   #94
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default
It'd be easy to check to see if a button had, say, no more than 1/2" of 'throw' to it. Then everyone wouldn't have to buy new buttons, just the guys with the long throw switches.
Michael Beard
Staging Light Graphic Design & Printing
Duck Tape/Loctite Racing
H - I - J/CM '80 Volare 360 Magnum
Old 04-24-2007, 11:31 AM   #95
SSDiv6
Default
Just put a removable collar on the switch and you will fool the inspectors on the amount of movement. Just do away with the switches and electronics and end of discussion.
Old 04-24-2007, 01:00 PM   #96
herbjr
Liked 83 Times in 32 Posts
Default
Stock should be footbrake only. SS if they use boxes but block the tree so you cant cross over you might see the slower car have an advantage. Especially if it over a 1.5 second spot. What do you think Beard.
Herb jr
herbjr is offline   Reply With Quote
Old 04-24-2007, 01:50 PM   #97
Michael Beard
Default
If that fools them, then they are not "inspectors". Most buttons I've seen have either been mounted in the steering wheel, on a mount next to the steering wheel, or next to the shifter -- all areas in which the 'back' of the button is not hidden.
But I'll agree... get rid of the stuff, and things become a whole lot simpler.
Herb - since I don't believe that delay boxes should be involved in S/SS racing, the rest of your question is a moot point. ;-)
Michael Beard
Old 04-24-2007, 02:00 PM   #98
QSTOCKER
Default
Here's a concept. NHRA could take a position like NASCAR and the restricter plates - NHRA would issue you a standardized "spec" button at the beginning of the event - everybody's the same.
Can you imagine the crying!
Chuck
QSTOCKER is offline   Reply With Quote
Old 04-24-2007, 02:12 PM   #99
Dick Butler
Liked 32 Times in 19 Posts
Default
Neat graphics and perfect comment. Really dont think a trans brake is needed in SS either...... Adjust your four link and go..
Dick Butler 3529
Old 04-24-2007, 02:19 PM   #100
Boo
Default
Wow, you put alot of effort into that post Mr. Ingognito. You must be getting some personal gain from it being "footbrake only"?,,?
But I don't agree with you on this. You will give more of an advantage to guys like Biondo, Fletcher, Bertozzi etc who grew up footbraking. Think about it.
Boo is offline   Reply With Quote
