Old 05-18-2014, 12:04 AM   #21
Damn Yankee
Default Re: BOSS 302 Rod Length Question
Jim Kuntz knows the 1968 302 SS/GT combo very well. He and SE Buchannon hurt some feelings in a bad way to include current Pro Stocker Greg Stanfield
Damn Yankee is offline   Reply With Quote
Old 05-18-2014, 01:46 PM   #22
Hans Olsson
Hans Olsson's Avatar
Originally Posted by FireSail View Post
OOPs 3369 for the convertible. Thought it was the heaviest 302. It's the heaviest gas engine offering of that model and year.
That puts the 302/260 Cougar engine at the bottom of GT/J close enough to move to GT/KA.
I think bracket racing what I have with a Holly 600 that would be legal on the 260 hp Cougar for this season and switching the pistons to flat tops over the Winter for GT next year is the best way to go. Carb specs for the 260 Cougar are 1563 1563 1250 1313 the Holly 80540-1 is a 600cfm carb with a throttle bore of 1563 and a venturi of 1229.
EDIT: The 68 Cougar 302 is 230 HP, but does have the Holley carb.That puts it at GT/MA with the heavy body weight of the convertible. The actual car, 68 coupe 302 is 2874. That's 495 lbs lighter than it's classification factor. Is that right? This is favorable, yes?
Dale
A car with 230 Hp in GT/MA (14 lbs per hp) has a minimum weight of 3390 lbs.
14 x 230 = 3220 + 170 lbs for driver.
Hans Olsson is offline   Reply With Quote
Old 05-18-2014, 02:31 PM   #23
Mark Ugrich
Liked 71 Times in 38 Posts
Just a thought ,but even if you did run the inline head,wouldn't you still have to use the "stock" domed piston for the boss motor? Even if you cut reliefs for the valves in a different location,I can't imagine it would make for a very efficient combustion chamber.
Old 05-18-2014, 03:46 PM   #24
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Stock style domes with valve reliefs, yes. A dome designed for the true BOSS head wouldn't be very efficient in an inline aftermarket head like the AFR 1399 but a dome with reliefs designed for the AFR would. You have to watch the math and keep it to a max CR of 10.5:1, 10.1 cc dome and a .047 gasket, though.
You can build a better combo without being the BOSS.
Dale
Dale Shearon
68 Mustang 6394
Old 05-18-2014, 03:52 PM   #25
FireSale
FireSale's Avatar
"Class is determined without driver weight"
Someone needs to run a thread that breaks the GT classification math down into steps. It's hard to read.
Dale
Dale Shearon
68 Mustang 6394
