Old 06-08-2014, 09:38 AM   #11
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Front tire size/Reaction Times/Mustang 5.0
Right side higher? Now you look like a stocker! Yep, that's preload.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 06-08-2014, 09:39 AM   #12
Billy Nees
Originally Posted by Bobby Fazio View Post
The air bag at 15lbs makes the right side of the car sit much higher than the left side at a standstill.
Try doing a little research into what was/is available as far as spring rates. If you can find a heavier rate with the same height, put it in the right rear with the air bag.
Billy Nees 1188 STK, SS
Old 06-08-2014, 07:09 PM   #13
James Hill
Liked 14 Times in 6 Posts
I would call and talk with Dave at team z as they are have some stock location rear drag springs made in a couple diffrent rates now that seem to be working well for people.
James Hill is offline   Reply With Quote
Old 06-10-2014, 10:39 AM   #14
Capri
Liked 27 Times in 14 Posts
The taller the tire, the better. Phoenix 26.7" roll out is about the max to fit in there without any cutting.
1 Cargo Coil spring in the R/R and a pair of bags will even out the stance of the car along with weight location. Shocks will control the rest.
Capri is offline   Reply With Quote
Old 06-10-2014, 06:35 PM   #15
dragracer9911
Liked 3 Times in 1 Post
Bobby, PM me. I may be a few days getting back with you.
Tom Sr.
dragracer9911 is offline   Reply With Quote
Old 10-16-2014, 08:36 AM   #16
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
If I get the Team Z bolt in anti roll bar should I take the airbag out?
'65 Mustang SS/L & L/SA
Old 10-16-2014, 09:04 AM   #17
rick978
rick978's Avatar
we are running two air bags rt side at 15 psi lt side at 6 psi drag springs adj uppers with traction action bars 4.56 gear (for now switching to 4.88 soon) no sway bar stock napa shocks 30 x 9.00 15 hoosiers with 18 psi car launches straight every time with a tall front tire great rt's 0.00 to .200 weight is 3180 runs 12.9 at 102 mph
rick978 is offline   Reply With Quote
Old 10-16-2014, 10:36 AM   #18
Rich67stang
Liked 116 Times in 27 Posts
The Air bag or anti roll bar will help, what RPM are you leaving at?, Try leaving higher.
That little motor makes no torque, so you need to twist the rubber band more, how much air in slicks
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 10-16-2014, 12:50 PM   #19
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Yes. The adjustment will now come from the preload you put into the ARB. The bag is now useless.
Mitch Beri- The Motor City
Old 10-16-2014, 03:24 PM   #20
Bobby Fazio
Leaving at 2800. Running 20lbs in the slicks. Bias Ply slick, haven't fit a radial under there yet.
