#31 |
That break was caused by the spun bearing.
Ed Wright 4156 SS/JA |
#32 |
Liked 13 Times in 11 Posts
Well , in the end , I blame myself for be stupid enough to A) continue to run it when I KNEW the rods had been in there for a while and B ) being too lazy to tear it down over the winter where I may have seen a problem.....but , like I said I'm a slow learner
#33 |
Liked 974 Times in 310 Posts
Bearings don't usually fail by themselves. The connecting rod dimensions change or oil supply changes.
#34 |
Or clearances were wrong to begin with.
#35 |
Not in this case. I'm a machinist for a major airline for 26 years.........and years prior to that. I have and have access to , every conceivable bore gauge and mic's anyone would need.
I assemble and check them........no chance in hell they were wrong. Generally .0025-.003 at the vertical. Or whatever the rod manufacturer suggests. I just ran it too long without an exam or freshening. |
#36 |
#37 | |
Ed Wright 4156 SS/JA Last edited by Ed Wright; 06-18-2014 at 02:30 PM. Reason: Still can't spell...... |
#38 |
Mine was instigated by detonation
Dion Hildebrandt 6009 STK H/SA |
#39 |
Well , I don't know what to tell ya........engine builders a lot smarter than me have run em that way for years........if I ran em tighter and it failed I'd be blaming it on that.........
#40 |
Yep. Hammering the bearings causes the ends to pull in & squeegee oil off the crank. Too much clearance often has the same effect, just takes longer.
