Old 06-01-2014, 05:00 PM   #21
Billy Nees
Liked 7,909 Times in 1,754 Posts
Default Re: 262 vs 267 sbc
Originally Posted by Dean Feiock View Post
So how does one work around the Dual Jet? Or should I ask how much HP can be made on a carb rated at 287 CFM?
It gets even more interesting if you convert apples to apples. Since a 2BL is flowed at 3 inches vacuum and a 4BL is flowed at 1.5 inches of vacuum, you need to multiply the 2BL CFM by roughly .707 to get a value you can directly compare to a 4BL carb.
So 287 X .707 = 203 CFM
Using a quick online CFM calculator:
267 CID, 5500 RPM, 80% VE........ would need about 350 CFM minimum
Well, let's see, with a (seriously) restricted engine you don't think about making HP. You make as much torque for as long as you can.
I can assure you that a 287 CFM 2V will be flowing at least 100% VE. How can I say that? If everything is right in the combo, the engine WILL be pulling vacuum long before it gets to the finish line. OBTW, try explaining that to the man designing your cam.
Billy Nees 1188 STK, SS
Old 06-01-2014, 09:01 PM   #22
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Billy, I understand the VE will be higher. I used a lower number in the calculation just for a number. To use 100% in the calculation would only further show inadequate the carb is.
Since the wife want's to drive and I've acquired another car......I guess I'll take a stab at it.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 06-03-2014, 12:04 PM   #23
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
I think that the 81-83 267@ 150 HP(79-80 are higher) is softer than the 76 262@ 171 HP.
To give a bit of perspective to what Billy is saying, compare the 267 to a Mopar 273 from the '65-'67 era:
Mopar - 287 max disp, 1.437 B&B carburetor that meters fuel like a straw in the wind, 10.2 compression, .400 lift cam, 176 power rating.
Chev 267 - 280 max disp, 1.375 Dual Jet that meters well, 9.5 compression, .357/.373 cam (heads will flow better on the exhaust than the Mopar), lighter reciprocating weight, better transmission (TH200), 150 power rating.
Not a cake walk, but very possible. The 273 has been beat on since the '70s, so don't expect to achieve the same level of performance in a month.
Old 06-19-2014, 09:35 PM   #24
brian schuetta
Liked 28 Times in 15 Posts
OK got a 267 block and crank but no heads. 513 castings look like one off deal. Will continue the hunt this weekend.
brian schuetta is offline   Reply With Quote
Old 06-20-2014, 12:36 PM   #25
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
What Billy said plus this
carb is rated 287,on dyno with air turbine will pull more than 287 cfm.
Mike Taylor 3601
Old 06-20-2014, 01:52 PM   #26
Billy Nees
Hey Mike, not for nuthin but a 267 and a 4 speed in your car would be a crapper full of fun!
