Liked 169 Times in 53 Posts
IWhat's the best way to adjust the PPS low travel lifter's. I've been tightened them down until I can just feel a little resistance on the pushrod and not depressing the lifter any at all. But this sure feels a little loose to me and it looks like it would be hard on the snap ring. Would it be better to bottom the lifter out (.012 thousands) and maybe use a .005 feeler guage to set them in the middle of their travel. Thanks for any help.
Bill Bogues 4696 STK |
Liked 101 Times in 27 Posts
I have a new set too and I would like to know the same info from a PP user directly. I was told to take them all the way down to the bottom of the travel and then back up until there is a slight spin on the push rod. I like the idea of using a feeler gauge better and your method sounds good if we can get some serious input from a PP rep or engine builder. Thanks for asking.
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 2,516 Times in 701 Posts
I adjust the low travel lifters where I can spin the pushrods with
fairly high effort but not visibly pushing the plungers down at all. Where to you buy these lifters with that short of travel?
Liked 166 Times in 71 Posts
I have the scorpion short travels, we are adjusting them by going to 0 with resistance on the pushrod, then 1/8 turn. Seems to work. Another fellow here had made a toll to hook on rocker and bottom them, then check lash with I think a .010 gauge, it was a supreme pita to check/adjust. He now doing the way I described with no difference in hp or et.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
Still hoping someone can tell me where to buy PPS lifters.
can be bought direct .....catalogue website PPPcenter.com, Arden,N.C.
Liked 880 Times in 311 Posts
John,
Check your PM's FYI: PPPC has the best pin in the business as well as lifters.
Adger Smith (Former SS) |
Thank You!
