Liked 293 Times in 65 Posts
Stick-only race this Saturday, June 28th at Mid America Motorplex in Pacific Junction, IA. I copied and pasted the following from Daniel Cech:
"B&E Stick Shift Challenge Calling all stick shift racers To Mid America Motorplex June 28th for the B&E Stick Shift Challenge! Come to the track and see if you have what it takes to win! This race is open to any and all Manually shifted Transmission cars and trucks from your occasional Friday night street car to your full on drag car. If you don’t have a stick car and just want to watch the high winding antics that is stick shift racing come on out. Gates open at 3 PM so ...come early get your car tec inspected and be ready for racing. Rules for stick shift challenge Standard transmission only, Lencos OK. Foot operated clutch required. Mechanical shifters only. . No air cylinders allowed. No clutch-turbos. Only full bodied cars and pickups allowed. All cars must pass NHRA, IHRA, and track tech inspection. One burnout across the starting line allowed---inform your opponent. Dry hop should not cross the starting line unless instructed by starting line personnel.). No computer, electronic or air shift allowed. Shifting must be done manually by the driver. No electronic device-throttle stop, delay box, or any other allowed. RPM rev limiter, play back tach, and commercially available data recorders allowed. Any device not meeting tech committee inspection must be removed before race starts--period! Full five-tenths tree. Practice courtesy staging. You may change your dial in between rounds. Quicker dial in has lane choice. During competition the car committing the first or worst foul is out and the other car is the winner. If the winner has broken (but was staged) it does not have to make the run but must break the beam and may return for the next round. If the winning car is not able to return, BOTH ARE OUT!" Again, gates open at 3pm. The track has new ownership and has made quite a few improvements already this year, so come on out! |
Liked 13 Times in 3 Posts
I doubt it. Once the first one red lights, he did it first. Even if the second guy leaves by a larger negative number, his foul is still not a worse infraction, a red light is a red light. Now if he crosses the center line, his foul is worse.
Chuck |
Liked 13 Times in 11 Posts
Since I'm such an attention w*h*o*r*e* , I'd rather be the only one at a local race..........the "outcast" factor is much greater that way.
