Old 07-04-2014, 09:52 AM   #1
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Modified Question???
I am getting back to work on converting out N/A 10.5 NMCA car to do some more localized NHRA divisional racing and looking at either SS/AM or BM, I have most everything else in place but we have been using a single 1050 dominator on this setup. I know the rules state I am allowed two approved 850's but can I still run a single dominator? I will eventually have a manifold built and a pair of 850's prepared, but would like to run the car next season for a few races...
Thanks..
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 07-04-2014, 11:46 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Modified Question???
In my understanding "Limited to two" means "Two and only two" 4BBL carbs. There is a sidebar that says you can run carbs from sections 1-2-3 but not over 850 cfm.
Dale
Dale Shearon
68 Mustang 6394
Old 07-04-2014, 03:58 PM   #3
FED 387
Liked 333 Times in 180 Posts
You are I think allowed up to 2 4bbl carbs or 3 2bbl carbs max-- if you want to run only one that is up to you--it does not say that it is prohibited but you better check with tech to be positive- missed the part about 850 CFM unless they are meaning 2 4bbl carbs of maximum 850 CFM each
Old 07-04-2014, 05:23 PM   #4
FireSale
FireSale's Avatar
Here's that section sidebar from the Accepted Parts thing:
"4. Any of the OEM or aftermarket accepted 600, 750, or 850 CFM carburetors listed in sections I, II, or III above may also be used in these classes. For these applications the throttle bore, venturi, throttle shaft and plate dimensions listed in sections I, II, or III apply for these carburetors only."
Dale
Dale Shearon
68 Mustang 6394
Old 07-04-2014, 11:28 PM   #5
FED 387
the key word here you are not seeing is "MAY" also be used---"MAY" it does not say you are restricted to just those carbs---but if you do use THOSE carbs then certain restrictions apply
Old 07-04-2014, 11:49 PM   #6
FireSale
FireSale's Avatar
This is getting a little academic, but I noticed something that actually relates to the OP's question as to whether or not he is limited to two carbs for 4bbl applications or can run one if he wants. The head for section IV in Accepted Products reads:
FOR CLASSES LIMITED TO TWO NHRA-ACCEPTED AMERICAN PRODUCTION 4-BARREL (INLINE PROHIBITED) OR THREE AMERICAN PRODUCTION 2-BARREL CARBURETORS MAXIMUM:
Applicable Classes: SS/AM, SS/BM, SS/CM, SS/DM, SS/EM, SS/FM, SS/GM
(My emphasis)
It reads like two is the max but not a required number when talking 4bbl.
Dale
Dale Shearon
68 Mustang 6394
Old 07-05-2014, 08:04 AM   #7
Freddie
Freddie's Avatar
Thanks guys, I guess another call to the tech line wont hurt. I am actually going to keep moving forward on this anyway, since it is already set up for one carb that is what I will run to start with even if it is just sorting out the car and testing. If I am not allowed to run AM or BM with one carb I may just put a little weight in it and try SS/AS, or if the field stays light move it into Comp and try my hand at one of the Super Modified classes....
I still have a bunch of work to do but I do have options...
Old 07-10-2014, 12:00 PM   #8
Rusty Davenport
Liked 101 Times in 27 Posts
I was at Gainesville a few years ago........Steve Johnson was told he must have 2 carbs it was not optional......it may be different now.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 07-10-2014, 12:29 PM   #9
Jim Caughlin
Liked 805 Times in 245 Posts
Maybe that seems strange but I know a couple of years ago, a racer in Div 6 got disqualified for running a single carb in Modified. Regardless of how you interpret the rulebook, I believe they mean multiple carbs, no single carbs. Might not make sense but that's the way it is.
Jim Caughlin is online now   Reply With Quote
Old 07-10-2014, 12:56 PM   #10
SSDiv6
Yep, Jim is correct. Got tossed out for not running two carbs.
