Old 07-07-2014, 10:10 AM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Help-Powerglide-big leak when on the brake?
Hi all,
Over the last couple of weeks, my glide has developed a leak. The case is OEM GM. We thought it was the pan gasket, but have now ruled that out. It is dry above the pan rail on the sides and front. It is only wet on the rear/driver side of the trans. Enough that the trans blanket and cross member are soaked after a run.
  • Testing with the front wheels up on the trailer tail gate, it is leaking when running and the transbrake is engaged. We swapped solenoids and no better. Since it was leaking, we didnt race and drove it into the trailer and I drove home. It did not leak in the trailer and nothing in garage after driving it from the trailer to the garage.
Trans was rebuilt before the season. It just started leaking about the 4th race into the season. I know that the solenoid has not been over tightened, but it is almost like the solenoid boss is cracked.
Just looking for any experiences that you've learned.
Thanks
Clark
Old 07-07-2014, 11:23 AM   #2
SSGN
SSGN's Avatar
Liked 144 Times in 52 Posts
Lightbulb Re: Help-Powerglide-big leak when on the brake?
Vent plugged or leak coming from the vent? Lots of guys running overflow cans today. I run one on my street car because it will leak out the vent on hot days when tranny temp gets up there.
Kevin
Old 07-07-2014, 12:08 PM   #3
Rick Shirey
Default Re: Help-Powerglide-big leak when on the brake?
Hate to be the bearer of bad news but if it only leaks with the t-brake is applied the most likely cause is the case is cracked in the reverse clutch pack area. The OEM cases are weak in that area.
Rick Shirey is offline   Reply With Quote
Old 07-07-2014, 12:10 PM   #4
Rick Schilling
Liked 14 Times in 10 Posts
I did not have a trans brake, but I had a similar issue a number of years ago with a glide. I had a stream of fluid hitting the left side header every time I put the car in reverse. That turned out to be a leak at a casting seam near the rear of the trans case. I had it welded a couple of times but only managed to redirect the stream each time, never stop it. Had to re-case the trans to correct the problem.
Rick Schilling is offline   Reply With Quote
Old 07-07-2014, 12:59 PM   #5
cad
cad's Avatar
Thanks for the replies. It's not coming from the vent. Trans was rebuilt and vent is new (and still clean)...I wish it was that easy. It has a blanket and nothing is wet up front/down the sides.
I am going to clean it up tonite, add dye and check it with a black light. We put an Ultrabell on last year and I figure it's time for the Ultracase. The car is now running 6.60s and the case is the last weak link (for now).
Clark
Old 07-07-2014, 01:08 PM   #6
SGSST109E
Liked 126 Times in 61 Posts
The OEM cases crack right on the parting line for the casting in the rear clutch area.
SGSST109E is offline   Reply With Quote
Old 07-07-2014, 06:17 PM   #7
Liked 1,909 Times in 427 Posts
This, seen it dozens of times. Often caused by chassis flex, mount problems, or in a dragster, tire shake.
Old 07-07-2014, 08:31 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Seems strange that the case should fail at that seam line. What line pressure do you run in Rev, and when the Trans Brake is on? Maybe the pressure is too high and stresses the case.
ss3011 is online now   Reply With Quote
Old 07-07-2014, 10:49 PM   #9
cad
cad's Avatar
Dye immediately showed when on the brake. dont know what pressure it is set at. Since the ultracase isnt available in time for a 3 race weekend, I ordered a 1 pc sfi glide case and have the trans pulled. Appt made with my trans guy for wed night if fedex shows up on time. He will swap everything over while I wait for $100. Ultrabell will be for sale...lol. dated dec 2013 I believe.
Old 07-08-2014, 07:29 AM   #10
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Check the driveshaft for run-out (before you pull the transmission back out) and get it balanced if you have time. I had an off center pinion yoke that was causing run-out and it killed 2 cases for me before I fixed the issue.
Pedigo Perf is offline   Reply With Quote
