Old 07-11-2014, 03:01 PM   #11
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Flexplate ?
Not ATI and seen it numerous times.
Old 07-11-2014, 05:49 PM   #12
voltdr
Liked 100 Times in 51 Posts
Most of the issues seem to be in the ring gear for the starter. I had a TCI (years ago) rip 5 teeth of in my pit getting ready for a TT at a Memphis national event. Missed the TT.
Dan
voltdr is offline   Reply With Quote
Old 07-11-2014, 10:25 PM   #13
Alan Nyhus
Liked 799 Times in 236 Posts
I've got first hand experience with what happens when a flex plate blows ('70 1/2 Z28). It's ain't pretty....I'm darn lucky to have all my toes and both feet.
The mfg. agreed this one shouldn't have gotten past their quality check. It's already on the way back to the supplier and a new one is on the way. -Al
"That'll never work....."
Old 07-11-2014, 10:35 PM   #14
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Dan
Same here only 8 teeth. No real reason as the replacement Pioneer has been fine so far.
Pedigo Perf is offline   Reply With Quote
Old 07-12-2014, 01:09 AM   #15
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Anyone remember Bonzi Starts? Put it in N, rev it up and punch L and pray. Saw a 442 Olds blow the trans at Milan in the '60s. Broke the drivers foot real good. Last time the owner allowed that.
Danny: TCI changed it's logo recently. Some sort of anniversary thing. I have a new TCI flex plate and I can't find any marking indicating made in Mexico on the plate or box. But then it's a Ford...
I may not need it, but I have a flex plate shield and a trans shield on a C4 behind a 302. I don't want to be that guy in the 442.
Dale
Dale Shearon
68 Mustang 6394
Old 07-12-2014, 07:42 AM   #16
racer913
Can having to much advance timing break teeth off ? Good starter 168 teeth plate 2 batteries 14.5 to one small block? JW plate is week old
racer913 is offline   Reply With Quote
Old 07-13-2014, 12:38 PM   #17
voltdr
Yes, timing can be an issue, especially with the engine hot. I have my MSD set to retard the timing 8*. Good grounding for engine block is a must. I run a #2 cable from the block to to the battery.
Dan
Old 07-13-2014, 03:09 PM   #18
Rob Petrie E395
Liked 216 Times in 77 Posts
If you dont have crank retard on your ign system. The other thing you can try is. Get the engine cranking. Then turn the ign on. It seems to help some guys I know.
Old 07-14-2014, 04:16 PM   #19
FED 387
Liked 333 Times in 180 Posts
I would be more concerned about the torque convertor bolt holes than a few small imperfections in the surface of the plate itself UNLESS they are numerous blemishes on both sides of the plate--- probably wise to send it back for a replacement !!! also check the area around the crank fange bolt holes thats where flexplates tend to crack the most
Old 07-14-2014, 04:33 PM   #20
Rusty Davenport
Liked 101 Times in 27 Posts
years ago I had the ears pull out of the converter and pulled the bolts through the converter holes at the same time, shrapnel cut the master cylinder off the firewall-no brakes at top end, cut the accelerator pedal off mounting shaft and took the heel off my shoe......all at the top end......careful out there......not to mention destroyed the bell housing and the safety cable help it up. If it can happen it will happen.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
