Old 07-14-2014, 05:42 PM   #1
AlanPetersJr.
Default 396 Cam question
Hi guys, just for my own curiosity, what camshaft does the 65 425 h.p.
396 use? I know that the big Chevy, the Vette, and the Z16 were rated at
425 h.p. For some reason I thought they used a hyd. camshaft. Also, how does
the 65 396 Vette fit A / Stock? Like i stated I am just curious.
Thanks in advance, Alan jr.
AlanPetersJr. is offline   Reply With Quote
Old 07-14-2014, 06:17 PM   #2
Superfan1
Superfan1's Avatar
Liked 2,638 Times in 440 Posts
Smile Re: 396 Cam question
According to the NHRA Classification Guide, the '65 Vette was factory rated at 425 HP, but, with OEM heads, it is NHRA rated at 375 HP, which gives it a factor of 8.06 which makes it a "natural" A/S car (8.00 - 8.49). With replacement heads it is NHRA rated at 385 HP which gives it a factor of 7.85 which makes it a "natural" CC/S car (7.50 - 7.99).
Bill Seabrooks - superfan1
Bridgeport, CT
Old 07-14-2014, 06:18 PM   #3
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Default Re: 396 Cam question
The original Z-16 1965 Chevelle (396) used a Hydraulic cam and was rated at 375 HP from the factory. The 65 396/425 Hi HP Vette used the same SOLID LIFTER cam as a 427/425 Vettes, Camaro, Big cars, and later 396/375 HP(1966 and up) Chevelles. It had .520 lift. Superfan 1 is correct on the later HP ratings with the replacement parts.
Old 07-14-2014, 06:34 PM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Alan, the '65 396-425's (Corvette and full size Chevys) had a mechanical lifter camshaft with .497/.503 lift. This was a different camshaft than the '66 and later 396-375's and 427-425's (.520/.520).
The '65 396/375 was only available in the Z16 Chevelle. That motor was virtually the same as the '65 396-425's with the exception that it used a hydraulic cam (.461/.500). Most people assume the '65 396-375 Z16 is an L78, which it isn't. It's actually an L37.
Hope this helps. -Al
"That'll never work....."
Old 07-14-2014, 08:11 PM   #5
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
What was the difference between the 1st design and 2nd design L-88 camshafts...I had that 1st design in a 427/425.69 RS Z-28( street car)
.To this day, I prefer the rattle of that old motor over any other camshafts....I'm sure different grinds made more power, but that thing sounded nasty....
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 07-14-2014, 08:45 PM   #6
Alan Nyhus
The 1st design L88's....'67 and '68 (even though NHRA doesn't recognize the '67)....were .562/.584 lift. The second design ('69) cam was a .560/.580. Even though the lift was close between the two, the profiles were quite a bit different. -Al
Old 07-15-2014, 07:47 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Same camshaft, just a clerical difference. If you look at the original (1965 version) of the NHRA Tech Bulletin, the part number is listed for the camshaft and it is the same as all the later L72 and L78 engines - 3863143 with a casting number of 3863144. If you research any and all of Chevrolet's documentation, whether it is parts manuals, production specifications or whatever, the 1965 engine used the same camshaft as every other 396 solid lifter engine built between 1965 and 1969 with lift specifications of .520"/.520". Chevrolet power manual lists the specifications of the same part number camshaft as "net lift" of .500" with lash settings of .024" intake and .028" exhaust. Maybe Chevrolet provided NHRA with net lift numbers in 1965, who knows. Regardless, the .497"/.503" numbers are in the 'Guide and we have to live with it.
Also, the hydraulic camshaft used in the 396-375 Z16 Chevelle is the same camshaft used in the 396-350/360 hp engines and 427-385/390/400 hp engines in 1966-1969, again with slightly different clerical numbers.
Old 07-15-2014, 08:14 AM   #8
Alan Nyhus
Yep...it's probably one of those odd things that just never got corrected in the Tech Bulletin. -Al
Old 07-15-2014, 08:27 AM   #9
james schaechter
Bob Gipson made that case with NHRA and they stick with the lower lift cam. That is what he has in his 65 vette A/Stick. Fun car and it is for sale.
James Schaechter 3163 STK
Old 07-15-2014, 08:51 AM   #10
Run to Rund
Liked 54 Times in 27 Posts
I agree that the first design L88 cam had a great sound. I can't get to my chevy power books right now but they showed the profiles, etc. iirc, it was about 264 deg. at .050" and rated duration was around 360 deg.
