Old 07-22-2014, 09:47 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Pinion angle
What is the desired pinion angle, '91 Camaro Stocker, A.T.?
Thanks in advance for your replies. J.R.
J.R. Haddad is offline   Reply With Quote
Old 07-22-2014, 11:54 PM   #2
Default Re: Pinion angle
sorry ...was thinking 81 Camaro ..no comment..carry on
Old 07-23-2014, 08:42 AM   #3
Signman
Liked 269 Times in 99 Posts
The desired pinion angle going down track should be as close to zero as possible at all angles for front and rear u-joints.
Put the front of the torque arm where it will be going down track and adjust to be as close as possible. The engine is offset to the right so be sure to look at those angles also.
Old 07-23-2014, 07:36 PM   #4
J.R. Haddad
Thanks Frank. That info will be very helpful. J.R.
Old 07-24-2014, 03:12 PM   #5
Stewart Way
Liked 70 Times in 22 Posts
Frank
On a Mopar the engine is also offset to the right as is the pinion. Is the pinion in the Camaro offset also? How far off center is the engine/pinion? Just curious.
Stewart Way 2424 SS
Old 07-25-2014, 05:19 PM   #6
Signman
Originally Posted by Stewart Way View Post
Frank
It's years since I did that measurement when building my stocker but 5/8" to the right is a recollection. Depending on what rear housing you put in it pinion location may not be where it needs to be relative to the trans. yoke. It's worth checking if your looking for maximum or near as possible efficiency.
Old 07-25-2014, 06:45 PM   #7
Pinion is offset 1'' in a factory 12 bolt. This is how you are able to use the same length axles both sides
