Old 08-05-2014, 03:44 PM   #11
pbp1
Liked 27 Times in 6 Posts
Smile Re: Weather stations
Originally Posted by Jim Kaekel View Post
I don't mean to intrude, but I imagine that he's referring to the fact that if you run your car on the "rich" side, that you would tend to pick up a bit more in very good conditions and fall-off a bit more when the air is real bad. On the other hand, if you run on the "lean" side, your car won't vary as much.
I completely agree with your first sentence, but if you run on the lean side of the ideal A/F ratio for your engine, you can have the same un-predictability in performance. As a matter of fact, it can even go the wrong way. I had a customer call me about a tuning issue, his complaint was that when he got in good air, his car actually slowed down instead of picking up. I asked him what his target A/F ratio was, he said 13.8:1, because "thats what everyone who is fast runs at".
pbp1 is offline   Reply With Quote
Old 08-05-2014, 04:29 PM   #12
Ed Wright
Ed Wright's Avatar
Default Re: Weather stations
Good grief! 13.8?? I think somebody is surely pulling his leg. LOL
Ed Wright 4156 SS/JA
Old 08-06-2014, 10:56 AM   #13
pbp1
Talking Re: Weather stations
Ed, you know the "Monkey See Monkey Do" mentality. For some application, 13.8 may be an ideal ratio, but it was not for this LS1. He refused to change it! He said it was the ECUs fault that his car slowed down in good air. I gave him the old "Garbage in, Garbage out" speech, to no avail! I try to communicate to people that an EFI system is just a tuning tool, it is only as good as the hands and mind that are using it.
Old 08-06-2014, 11:52 AM   #14
Ed Wright
Ed Wright's Avatar
I have found that many wide bands, unfortunately, are like flow benches and dynos, as they don't all give the same numbers on the same engine. I have done this a while now, and have never seen anything on my dyno like 13.8-1 on any wide band of mine. I can't imagine him falling for something like that. He needs sharper friends. LOL
Mine always goes down the track quicker when a tad richer than it liked on the dyno.
Old 08-07-2014, 12:06 PM   #15
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Ed - I know 14.7 is technically ideal, but what would a good range be for a Q-jet SBC stocker?
Paul Merolla is offline   Reply With Quote
Old 08-07-2014, 07:36 PM   #16
Ed Wright
Ed Wright's Avatar
Paul, 14.7-1 is not for wide open power. That is the target A/F ratio for computer controlled cars with cats. That is where the cats are most efficient in most cases. That is for idle and cruise, not WOT.
Most everything I ever worked with has liked between 12.5-1 and 13.2-1. Some depends on the fuel also. C11 likes a little richer. My car likes 12.8-1 with C11. Your results may vary. LOL
Old 08-08-2014, 12:00 AM   #17
Nitro Joe Jackson
Nitro Joe Jackson's Avatar
Liked 67 Times in 19 Posts
Computech is my favorite , great support group and tell Jay "Nitro Joe sent you"!
and I know a good guy to bail you out if you have computer problems with there weather at the track, lol
Nitro Joe Jackson STK 3431
nitrojoe@neo.rr.com
Old 08-09-2014, 08:52 AM   #18
Paul Merolla
I should've said "stoichiometrically" ideal...thanks for the info.
