Old 08-22-2014, 12:52 PM   #1
mnmatt
Default Ss/mx
I'm looking at getting into drag racing, I build my own engines and have my own engine shop; is this a bad class to try to get into?
mnmatt is offline   Reply With Quote
Old 08-22-2014, 01:38 PM   #2
Isaac Zane
Isaac Zane's Avatar
Liked 50 Times in 14 Posts
Default Re: Ss/mx
It is a good class. Pretty simple engine wise, just a pounds per cubic inch class. Of course it is a non-V8 class. My uncle ran this class for many years from the Modified Eliminator days of J,K/Gas and then SS/BX and SS/AX with the Opel GT with a Buick V6. Up until recently he ran SS/TD with the same combination in a Chevy S-10 pick-up. Rich Oakes currently runs SS/BX, SS/CX, SS/GM and occasionally SS/DS(?) with his 3rd gen Camaro with a Chevy V6. Ed Newton is running SS/AX with his Monza.
Not too many heads-ups to worry about although at least one year there were 6 SS/AX'rs at Indy!
There are others on this site that can help you out more I believe.
Good luck, Have Fun!
Isaac Zane STK 1237
J/SA Buick Apollo
Patriot Guard Rider DOOF 43
Isaac Zane is offline   Reply With Quote
Old 08-22-2014, 02:10 PM   #3
mnmatt
Default Re: Ss/mx
If I were to run a inline 6 chevy can you run any cylinder head you want or does it have to be original factory?
Old 08-22-2014, 07:30 PM   #4
Rsmith38
Liked 28 Times in 15 Posts
Default Re: Ss/mx
A straight six will NO WAY be competitive against V6's (which in the 2009 rule book I looked at) seems to be the case. on a straight cu in comparison in this class. Suggest you rethink classes before investing time and money. Think 1985 when all the D/Dragsters became obsolete with straight 6 - then NHRA split out the V6 in its own class -- but I don't see that in the SS/MX rules???
Rsmith38 is offline   Reply With Quote
Old 08-22-2014, 08:19 PM   #5
Jim Caughlin
Liked 807 Times in 247 Posts
Default Re: Ss/mx
SS/AX through SS/CX are owned by V6 motors, no chance in the world that an inline motor is going to be competitive. Under the index maybe but not going to in any way competitive against a V6. These classes were orig intended for imports and small motors, NHRA allowed V6's later (probably petitioned by someone) and the party was over after that. If I recall, SS/CX had a 11.35 index just a couple of years ago and got creamed in one fell swoop by a V6 car. The logical thing would have been to put a big weight adjustment for the V6's but that's not how it worked out.
Jim Caughlin is offline   Reply With Quote
Old 08-22-2014, 10:44 PM   #6
mnmatt
Default Re: Ss/mx
how fast are the v6 cars? how heavy are they?
Old 08-23-2014, 01:22 AM   #7
THoagland
THoagland's Avatar
Default Re: Ss/mx
ss/cx is 12.5 lbs/ci with a minimum weight of 1700
THoagland is offline   Reply With Quote
Old 08-23-2014, 11:33 AM   #8
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Default Re: Ss/mx
When I drove Ed Newton's SS/AX Monza a couple years ago, the minimum weight was 2235 lbs with a 275 CI V-6. I went as quick as 8.85 @ 152 on a 9.50 index.
Old 08-24-2014, 12:10 AM   #9
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Ss/mx
It takes a Splayed Valve V-6 to be competitive in SS/X classes. I haven't seen an in-line 6 run like the SV- V-6.
To build a SS A/X car it has to be very lite weight in the 2200 lb area. Anything bigger than a 280-285 cu in V-6 will make all the cars too heavy to compete. Most good are 280 and under. I have 2 - 278 cu in and a 266 cu in engine. It takes making 2.25 + Hp per cu in.
This is a test pass in SS/DS which is like a SS/X class except there are some body rules and a 750 carb rule.
Right now I'm out due to family health issues.
If you want some good parts to start with let me know. I might consider selling the car.
Adger Smith (Former SS)
Old 08-24-2014, 12:40 PM   #10
mnmatt
Default Re: Ss/mx
Does the cylinder heads and block have to be the same manufacturer?
