Old 10-16-2007, 03:34 PM   #1
Pontiac Lee
Question Corvette proportioning valve
I am replacing this valve on my 70 Corvette. It has an electrical connection on it. Can someone tell me what purpose it serves and where the wire leads. Thanks, Lee
Pontiac Lee is offline   Reply With Quote
Old 10-16-2007, 03:37 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Corvette proportioning valve
Low brake pressure warning?
Jeff Lee 7494 D/S '70 AMX
Old 10-16-2007, 04:35 PM   #3
L79racer
L79racer's Avatar
That one wire would be the low brake light.
L79racer is offline   Reply With Quote
Old 10-17-2007, 02:31 PM   #4
Pontiac Lee
Thanks L79 and Jeff for the info. I think the valve is stuck as I can't bleed the rear brakes. I tapped on it while putting pressure on it, but to no avail. I guess a new valve is in my future, eh? Thanks again. Lee B.
Old 10-17-2007, 04:39 PM   #5
Harry 6674
Some of them have a small (1/8in.) plunger that pops out that needs to be pushed in to reset.
Harry 6674 is offline   Reply With Quote
Old 10-18-2007, 07:18 AM   #6
Dave Goob Cook
Dave Goob Cook's Avatar
Frequently, to re-set that valve once it goes off center, (that is how the indicator works) you MUST have that wire hooked up, ignition on, then bleed off the pressure from the side that has pressure, to re-center the valve.....why it only will re-set with power applied I'm not sure, not all of them require it, but it might.....
Anyway, you always have to work the system front/rear/front/rear to keep the valve centered.
The purpose of it is to cut off fluid flow to the side that lost pressure, like if a hose or tube burst.....
The valve is actually un-needed to proper brake operation, especially on a 50/50 brake system like the Corvette......easier to plumb around it if this isn't a restoration street car.
Dave Goob Cook is offline   Reply With Quote
