Old 09-03-2014, 10:42 AM   #51
Bobby DiDomenico
Liked 101 Times in 52 Posts
Default Re: SS/JA should be good!
I don't know how much he will get. Do you? If you are correct, they always run it more than that heavy anyway.
Interesting Ed,
Do they not use the actual run weight when calculating HP? If you are already getting factored at a weight heavier than you will be required to run in the future the system is even more flawed than many here feel it is:-)
Old 09-03-2014, 11:13 AM   #52
Ed Wright
Ed Wright's Avatar
Originally Posted by Bobby DiDomenico View Post
Interesting Ed,
No, Bobby, a lot of us run heavy to avoid hitting the 1 under trigger and to keep our AHFS average down. They run that car more than 100 over weight anyway. As far as I know, NHRA doesn't monitor what we go across the scales at. Hope not anyway. :-)
When mine is healthy I usually run it 140 heavy. I didn't need to as weak as it has been these last couple of weeks. I finally took all the weight out at Indy, and best it went was -.879.
Need to get it back out of the car. I think know what it needs now, to get back where it was. Won't be as fast as Ricky's, but better than it is.
Ed Wright 4156 SS/JA
Old 09-03-2014, 11:19 AM   #53
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Talking Re: SS/JA should be good!
Sounds like a pretty good combo.
Old 09-03-2014, 11:23 AM   #54
Jeff Niceswanger
Liked 1,063 Times in 376 Posts
Is Ronnie Terrell's car bogus? He killed ten MPH and ran quicker (9.805) than any SS/JA car there. Then screwed with it before the next round, and could only run 9.85 out the back door. He changed it right back. :-)
I've thought for a long time Ronnie had the fastest SS/JA car on the planet. I still do. Ricky is not far off. He is bad fast.
I was in the other lane when Ronnie went the .805. I don't understand this "after the race " conversation . Decker beat us ALL. Class at Indy is over.... Same day, same track..
BTW.... When Ronnie and I ran in the morning the Air was 2750.... I helped Rickey in the final and the air was 1000 feet worse and we had lost some tailwind.
Jeff Niceswanger 3740 SS
Old 09-03-2014, 11:28 AM   #55
442OLDS
442OLDS's Avatar
Interesting Ed,
Where is the "LIKE" button?
Old 09-03-2014, 11:44 AM   #56
Randall Klein
Liked 316 Times in 67 Posts
You can run heavy, but a few years ago you could not weigh more than the next lower class, i.e., I cannot run SS/MA at SS/NA weight. A minor point since hardly anyone runs that heavy, but at Norwalk about 3 years ago Travis held a meeting in the trailer at Tech explaning that
It may have changed
I did observe a racer removing 200 lbs at Joliet one year...hard to do when its "welded in"
Old 09-03-2014, 12:30 PM   #57
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
The 360 will receive 9hp. The old minimum weight for SS/IA was 2920. It will now be 3010.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 09-03-2014, 01:16 PM   #58
Ed Wright
Ed Wright's Avatar
Don't think that will bother that car much, do you?
Old 09-04-2014, 12:49 PM   #59
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
How many cars actually run near minimum anyway? Not many, I'm guessing.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 09-04-2014, 02:32 PM   #60
Ed Wright
Ed Wright's Avatar
I'm usually 140 over, except the last four weekends where it had slowed down so bad.
Had all the weight out on the 10.12 pass. No weight, no restirctor plate, still slow. LOL
Just need to get the car out of the trailer, and take it back apart. It's only money, right?
