Old 09-05-2014, 03:03 PM   #1
Troy Pourciau
Default NHRA Disqualifies Two Competitors during the Chevrolet Perfo
NHRA Disqualifies Two Competitors during the Chevrolet Performance U.S. Nationals.
#1 - supercharger pulley did not meet specs.
#2 - false battery installed.
Troy "City Dog" Pourciau
Old 09-05-2014, 03:27 PM   #2
robzneed4speed
robzneed4speed's Avatar
Liked 243 Times in 32 Posts
Default Re: NHRA Disqualifies Two Competitors during the Chevrolet P
I spoke to the gentlemen with the false battery. It was a borrowed ride and he
was unaware. He wanted to fix it but NHRA wouldn't let him.
Robzneed4speed Videos
www.robzneed4speed.com
Old 09-05-2014, 03:33 PM   #3
PontiacManiac
Liked 24 Times in 1 Post
I had a fake battery in tech a couple years ago they found and we didn't even know it was a fake battery...Bo actually argued with the tech guy about it until we unscrewed it and lifted it up. There were quite a few of us that had them and it was more annoying than anything. I don't understand why they care so much about that. It is still stock appearing. I can't believe they would throw someone out for that.
PontiacManiac is offline   Reply With Quote
Old 09-05-2014, 03:51 PM   #4
Wayne Kerr
Liked 26 Times in 11 Posts
I have it from a good source that the supercharger pulley was larger than the specification.
There is no plus or minus tolerance on the pulley spec's. unlike crank stroke.
The rule needs to be clarified before a competitor gets pitched. Not a good call by the NHRA.
See you at the races,
Wayne Kerr
Wayne Kerr is offline   Reply With Quote
Old 09-05-2014, 03:56 PM   #5
Ed Wright
Ed Wright's Avatar
Wayne Kerr
I was told the pulley was smaller, by another supercharged CJ racer, and that he should have had another 120 lbs in the car to run that pulley.
Ed Wright 4156 SS/JA
Old 09-05-2014, 07:43 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,199 Times in 977 Posts
NHRA had busted a few on this earlier this year and even put a reminder on NHRARacer. So with all those warnings it was probably pretty cut and dry as far as they were concerned.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-05-2014, 09:15 PM   #7
Evan Smith
Liked 115 Times in 5 Posts
I believe the pulley was too large and there is a spec on the pulley diameter.
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 09-06-2014, 12:17 AM   #8
Mike Schwartz
Liked 248 Times in 89 Posts
Classracerinfo.com shows a spec of 3.5" upper and 8" lower on the pulleys for the 2013 CJ (2014 won't load). If you are using OEM pulleys and wanted to argue that the OEM manufacturing tolerances are unknown, how much deviation from the posted specs should you be allowed? Up to 1%? 5%? 10%? At what point does it become an unfair advantage?
Does anyone know how far off spec the pulley actually was?
Old 09-06-2014, 12:56 AM   #9
Troy Pourciau
Tech inspectors discovered the supercharger pulley did not meet NHRA specifications.
That all it says Mike.
Old 09-06-2014, 06:41 PM   #10
Jason
Liked 6 Times in 4 Posts
Wayne Kerr
Your good source should have told you that the pulley was from a different year Ford supercharger. Thousandths of an inch had nothing to do with the DQ. Using a different OEM Ford pulley from another year is what got the racer tossed.
Jason is offline   Reply With Quote
