Old 09-08-2014, 12:04 PM   #11
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: EMI / RFI and setting timing = problems
Can't really say I prefer any brand wire...Firecore makes what is probably the quietest wire out there, but again I would say your MSD wires are probably not the cause of the problem just yet. So you're saying the strobe is on all the time never flashes? WOW that would require A LOT of noise, any chance your coil wire is near where you're hooking up? that one is hot nearly all the time with engine running. I'd try seperating the wires out as far as I could, leave all other components off (water pump fan ect.) and try again.And yes, if your trigger wires were reversed you would see 10 degrees of timing change but it would be steady.
Joe Buchanan SS/BX 3117
Old 09-08-2014, 12:05 PM   #12
joespanova
Liked 13 Times in 11 Posts
Originally Posted by Sean Marconette View Post
Joe FWIW, the wires I had were Accel 8.8 and it was suggested to install MSD 8.5 wires and the filter have never had a noise issue again.
Does the light do the same thing if clamped to a different plug wire?
Is the power and ground for the MSD box going straight to the battery?
Sorry for all the questions it's the only way to rule out stuff.
Sean
I dont mind the questions...thats why I'm here.
This grief is a pain in the arse to trouble shoot.
What filter and where is it?
I'll try another wire later today
Old 09-08-2014, 12:07 PM   #13
joespanova
Originally Posted by buzzinhalfdozen View Post
Can't really say I prefer any brand wire...Firecore makes what is probably the quietest wire out there, but again I would say your MSD wires are the cause of the problem just yet. So you're saying the strobe is on all the time never flashes? WOW that would require A LOT of noise, any chance your coil wire is near where you're hooking up? that one is hot nearly all the time with engine running. I'd try seperating the wires out as far as I could, leave all other components off (water pump fan ect.) and try again.And yes, if your trigger wires were reversed you would see 10 degrees of timing change but it would be steady.
LOL , no I didnt say its on "all the time" in THAT respect , I meant on all the time as it would be normally........just not readable.
Old 09-08-2014, 12:57 PM   #14
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
http://www.msdignition.com/Products/...,_26_Kufd.aspx
I would not go buying this unless you have exhausted everything else.
Sean Marconette
84 Mustang
5060 SS/N
Old 09-08-2014, 01:04 PM   #15
joespanova
So in addition to the other suggestions the nutbag at MSD suggested , why the hell dont they just suggest this?
Anyway , thanks. I look at everything else first
Old 09-08-2014, 03:06 PM   #16
buzzinhalfdozen
Yeah I've put at least 50 or more MSD ignition systems on cars, from basic 6al to the digital stuff and have never installed one of their filters. Though it's possible it may cure yours I'd bet if anything it may mask the real problem. I'll assume you've went back thru and verified all connections and lay out of wiring is correct? Main power and ground go to batt. positive and negative? Believe it or not if those 2 things aren't true you can have some real issues. I've seen some pretty cobbled up installs of MSD systems and for the most part they all worked, however as with most things when they add more "stuff" (digital systems) the proper installation is more critical. Make sure you've got all the wires ran correctly, not just the way they were with your old system. One last thought...where is your controller mounted at least in relation to the coil and high voltage lines?
Old 09-08-2014, 04:16 PM   #17
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I know that you are not going to believe this.......But I made a mistake ONCE
I had the pickup polarity reversed and the timing mark bounced around like crazy. This was on an MSD-7A and crank trigger....
With the shielded leads they did a color swap and that caused my problem....
I reversed the leads and the problem went away....
It seems like a pretty easy test to do and it might solve your problem..
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 09-08-2014, 04:42 PM   #18
Sean Marconette
Bob
That's what I experienced too Bob! The timing was jacked as well! All because I replaced the Ford distributor adapter to MSD plug with Weather pack connectors. We are our own worst enemies at times!
Sean Marconette
84 Mustang
5060 SS/N
Old 09-08-2014, 08:35 PM   #19
joespanova
OK , Lets end this .......thanks for all your input BTW.
I had a friend of mine stop by with his plastic ( newer than my metal body ) Actron light......and it read the timing!
Actually surprised the crap outta me........anyway , my lights that normally work are suddenly quirky..........all those lights ( 3 ) are years old with the exception of my Flaming River light.......but his worked.
Anyway , I'm buying another light ( same as his ) now I'll have 5 lights LOL
Old 09-09-2014, 09:47 AM   #20
buzzinhalfdozen
Glad you found your issue, my first thing when someone local has this issue is to use my timing lite to see if that's the problem, then go from there. Guess one can never be sure. BTW you actually will only have 1 lite that works on your race car!
