Old 09-14-2014, 11:41 AM   #1
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Default G/SA low qualifier at Thunder Road
What is this combo? I wasn't even born in 1964.
Old 09-14-2014, 12:21 PM   #2
Liked 1,843 Times in 418 Posts
Default Re: G/SA low qualifier at Thunder Road
There is a single 4 barrel 383/330/280 that seems to come close to fitting the class, looks like it might be a good combination.
Old 09-14-2014, 12:34 PM   #3
442OLDS
442OLDS's Avatar
Question Re: G/SA low qualifier at Thunder Road
426 originally 365 horsepower, NHRA rated at 291? And people complain about new cars?
Old 09-14-2014, 01:48 PM   #4
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
LIKE!
There is lots of "soft" combos out there. Racers just need to be smart enough to recognize them!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 09-14-2014, 02:24 PM   #5
james schaechter
Liked 1,436 Times in 299 Posts
Looks like his cars are always well cared for and don't want for much either. I bet the same car with less than thoughtful testing an prep would be just another .4-.5 under car. It isn't like he bought it complete like the new cars. Going Mopar now 442?
James Schaechter 3163 STK
Old 09-14-2014, 02:24 PM   #6
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Very well put Sean! There are plenty of fast old dodge combos just takes some keyboard surfing. However, it still takes some work it isn't always plug and play just because it's good on paper.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 09-14-2014, 03:20 PM   #7
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The 426 Street Wedge is a flat top piston, fairly low comp combo with an AFB that flows 566 and 430 lift hydraulic. From the factory it makes about the same power as a 361/305 which had basically the same carb , heads and cam. If it was such a killer combo, there would be dozens of them out there.
Old 09-14-2014, 03:24 PM   #8
Barry Polley
Guest
Posts: n/a
Biggggg differance between writing cars into classes or better yet, reading the class guide and taking advantage. It existed! Hats off to Jim and his guys.
FX_@NHRA.com Fix this please....
Old 09-14-2014, 10:57 PM   #9
John Bender
Liked 61 Times in 12 Posts
All the 383 Dodge and Plymouth engines from 1963 to 1967 had an almost flat intake, 550 cfm afb carb, small exhaust valve heads, and a 430 lift cam. The factory rating horse power was to help in the showroom. Paul covered the 426 street wedge. Hats off to Jim Hale and John Shaul who found a way to make these combinations run very well. A lot of R&D. Not a fat wallet.
John Bender 1969 STK
John Bender is offline   Reply With Quote
Old 09-15-2014, 10:25 AM   #10
Run to Rund
Liked 54 Times in 27 Posts
I wish NHRA would de-rate the Olds 400 engines. I haven't seen any in NHRA since Sam Murray's car in 2006. There are a number of old combinations that would be good to see out there but they were factory rated for showroom appeal and are too high for today's competition.
