#11 | |
Liked 93 Times in 52 Posts
Which part number did you use? K5250? Jegs is not model specific enough to be certain. Thanks Clark |
#12 |
Liked 800 Times in 237 Posts
Yes, pn# K5250. -Al
"That'll never work....." |
#13 |
Liked 56 Times in 29 Posts
Some upper A arms use grade 8, 3/8" fine thread bolts at the ends of the shafts. Others have longer shafts with big nuts on the ends. If header clearance allows, you could use them instead.
#14 |
Liked 55 Times in 26 Posts
I redid the front end of my 74 nova last spring and used the afco bushings moog offset top shafts and long ball joints.. made a HUGE difference in my car.. It is so smooth now and drives much better... Would do it again in a heartbeat..
