Old 10-04-2014, 12:23 PM   #11
Default Re: Gm 6.0 litre v v t v8 tow vehicle engine
Originally Posted by Jim Cimarolli View Post
I don't own one, but I have worked on my share of them. Sadly, I rarely ever hear anything good about a 6.0 when it comes to towing and mileage.
If the one Kevin had, '09 GMC 2500HD crew cab 4x4, is any indication, I'm sure you're hearing correctly. He never liked it. I could nurse 12MPG out of it with an open trailer on the Interstate, but it took some real work, and it never was nice to drive.
While I'm reliably informed you can work wonders with some PCM tuning, the results, I hear, put it on par with a stock 8.1.
Kevin sold the '09 GMC, and bought an '02 Chevy, same truck except 8.1 and an Allison, he's real happy now, where he was real annoyed before.
I've got an 03 2WD 3500, 8.1 and an Allison, I'm pretty happy with it stock. I'm sure my list of future upgrades will leave me thrilled.
Old 10-04-2014, 04:01 PM   #12
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi Guys,
My last fill up was at a Pilot Station and the Regular Unleaded 87 was $3.39 a gallon and the Diesel was still up at $4.09 a gallon...
That's 70 cents a gallon difference.....
Welcome to California........
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 10-05-2014, 05:49 AM   #13
SGSST109E
Liked 126 Times in 61 Posts
I bought a new 2500 2014 crew cab 6.0 with 4:10 gears to replace my 1999 suburban with a 454 that was getting tired. I tow a 28 foot trailer total weight about 9,000. I actually get better mileage in tow mode. Towing I get 8 to 11 mpg depending on terrain. When not towing I get 13.5 as an average. Straight highway by itself I have hit 15.4mpg.
SGSST109E is offline   Reply With Quote
Old 10-05-2014, 08:17 AM   #14
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Never had a newer gas Chevy but have an '07 2500HD crew cab long box LMM duramax and would never tow with anything but diesel again. I can get 12mpg with the family and the 24'. Another thing to think about of diesel over gas is longevity, the diesel will always outlast a gas when apples to apples conditions.
FrankM is offline   Reply With Quote
Old 10-05-2014, 10:02 AM   #15
I saved about $6K not buying a diesel. I do not need to worry about extremely expensive fuel injectors, fuel injector pumps, or turbochargers.
My 8.1L, with proper maintenance, will probably go 250K miles. At which point, even with substantial upgrades, will not require a lot of money to rebuild.
Any repairs needed by my 8.1L are very quick and easy, and usually relatively inexpensive. I have not had to touch mine, just going by experience.
The same cannot be said for a diesel. I've worked on them. Everything is expensive, and most of it is difficult or at least very time consuming.
Again, I'm speaking about an 8.1L, not a 6.0L, which I would not want in a truck I was going to tow with.
Sure, a DuraMax will probably blow right by me, and it will get 30% better fuel mileage. I can live with that. Especially for the price difference.
Old 10-05-2014, 11:10 AM   #16
james schaechter
Liked 1,443 Times in 302 Posts
I love my duramax I irdered it new in2002 6 speed stick 4 x 4. It was 35k out the door and has 347,000 on it. I avg 20 mpg in the Chicago suburbs. Problem for me is that a comparable replacement is 65k or more.
I have been looking into. 2500hd gasser but the talk about 6.0 liters is discouraging. All of the diesels suffer on mpg with the emissions so it is really hard to justify.
My brother has a suburban 1500 with a 5.3 and I towed straight through from belle rise to Illinois once with no issues getting 10 mpg. I guess I assumed , more cubes and an Allison six speed would be hard to beat. I only have a 24 ft trailer , but I guess I need to do more research.
James Schaechter 3163 STK
Old 10-05-2014, 11:57 AM   #17
I bought my '03 used, with under 75,000 miles on it, for $15K, and it is a loaded cream puff, ask Kevin next time you talk to him. If you look, they're out there, I found a 1/2 dozen. My old bank screwed up and I missed a nice '06 GMC with 72,000 miles for $13K. At the same time, I passed on a garage kept '05 with a stick with under 77K for around $15K, it was not as loaded as mine, but was owned by a drag racer who did a lot of business with the dealer outside Atlanta.
Old 10-05-2014, 03:45 PM   #18
james schaechter
What does your 8.1 get for mpg towimg and empty?
Old 10-05-2014, 04:46 PM   #19
Around 12 running close to 80MPH empty, and around 10 running near that fast with an open trailer and a 3400# vehicle.
Ed Wright says there is much to be had with his program, a couple of guys have told me it is worth 2-3MPG.
I know for a fact my tires are too short, an my gear too low. I can drop 200-400 RPM and pick up 2MPG.
I'm actually looking at converting to taller medium truck tires, for more load and towing capacity, and lower RPM.
Old 10-05-2014, 05:14 PM   #20
Lynnmsp
What program are you or Ed using? I have 03 8.1 with Allison trans and getting 10-11 and 12-13 highway.Thats if I drive 55-60 mph.My tires are one size larger than stock.Its a crew cab single rear wheel 2500HD with 4:10 gear.
Lynnmsp is offline   Reply With Quote
