Old 10-21-2014, 09:24 AM   #11
Ed Wright
Ed Wright's Avatar
Default Re: TBI fuel injection issue...
There is more to it than simply replacing the coolant temp sensor. I have fixed many like this over the years by cleaning or correcting loose/high resistance connections in that circuit, at both ends. As I mentioned, high resistance = lower than actual temp indications to the ECM. That is the reason for cold soak checking the coolant temp with your scan tool. Trying to work on an EFI vehicle without a good scan tool is like trying to work on a carb with no screw driver.
Another thing I forgot to mention is the tendency of those older TBI trucks to clog (with black. carbon/coke) the vacuum passage to the MAP sensor hose nipple in the back of the TBI, causing lazy response of the MAP sensor. If the ECM is seeing lower than actual manifold vacuum causes it to mis-calculate load, and reference cels in the wrong area of the V.E. Table, and making it run too rich. This is a mileage killer, for sure. A kinked, or leaking vacuum hose to the MAP sensor will cause that also.
I have seen many more low coolant temp indications cause cold start up problems in my shop than anything else.
Ed Wright 4156 SS/JA
Old 10-21-2014, 11:18 AM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If you don't have access to a Tech1 or a SnapOn Scanner, You can get a decent scanner cheap from Harbor Freight, amazing how low the price is , if you have a discount coupon !
Old 10-21-2014, 11:33 AM   #13
Mark Ugrich
Liked 71 Times in 38 Posts
The problem could be any of the things suggested. Using a scan tool and checking for codes will help guide you in the right direction.There are diagnostic aids for each fault code in the service manuals.
Old 10-21-2014, 12:44 PM   #14
Ed Wright
Ed Wright's Avatar
What he is describing is not likely to set a code.
Those older trucks, no check engine light = no code.
Later OBD2 vehicles will set some codes with no light.
