Old 10-25-2014, 09:56 AM   #1
Frank Castros
Liked 2,750 Times in 971 Posts
Default looses power
GT/HA '66 Plymouth Belvedere, 426 Street Wedge, 3,675 lbs.
2.77 first gear ratio, 4.89 rear gear, shifting @ 6,500 rpm, 7,500 rpm at the finish line.
1.44 60', 4.35 @ 330, 10.80 @ 122.00 mph.
Problem is it runs out of steam at the top of the first gear.
Running an Edelbrock Super Victor with a Carter AFB 585 cfm, fresh Product Engineering 9500 Fuel Pump and 4 port regulator.
What do you guys think?
Old 10-25-2014, 01:37 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: looses power
Hi Frank, Jim Hale could be very helpful with that combo but my thought is you're turning it too high, I would go with a 4.56 gear and back to a 2.45 first and advance the cam a little.
Old 10-25-2014, 03:09 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
Try shifting 1-2 at 6000-6200 see if it goes faster.
Lee Valentine 1661 STK
Old 10-25-2014, 04:19 PM   #4
Ed Wright
Ed Wright's Avatar
I was thinking the same thing. I always have to get out of low gear much sooner than second.
Ed Wright 4156 SS/JA
Old 10-25-2014, 04:35 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: looses power
Just to be on the safe side, if clearances and other factors allow it, try upping spring pressures a bit. It's better to have a LITTLE more than needed than a little less. Do some research on what your overall engine combo should like in springs.
Being a long stroke big block, it could work better with less rpm, as suggested.
LOCOMOTION Racing
Old 10-25-2014, 08:36 PM   #6
Frank Castros
Okay, I'm good with lower rpm, but I'm thinking the intake has too much plenum and runner, agree?
Old 10-25-2014, 08:58 PM   #7
Ed Wright
Ed Wright's Avatar
Too much plenum or runner cross section won't cost power at higher RPM. My experience has been the other way around.
Old 10-26-2014, 12:07 AM   #8
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
426ci + 525 CFM don't = 7500 rpm at the end or 6500 rpm on the shifts..
Just sayin'
PS:
But I could be wrong......................
Bob Mulry 7516 STK
A & M Motorsports
Old 10-26-2014, 07:37 AM   #9
Frank Castros
Just sayin'
PS:
Please explain your thought.
Old 10-26-2014, 07:50 AM   #10
Myron Piatek
If I may.....Try breathing through a straw (small carb), then try breathing through the cardboard spool out of a paper towel roll (big carb). You can only take in so much air in so much time through a small hole. The restriction doesn't allow you (or the engine) to breathe enough volume quickly enough to satisfy the needs. (High rpm or you running.)
LOCOMOTION Racing
