Old 11-11-2014, 02:45 PM   #31
joespanova
Liked 13 Times in 11 Posts
Default Re: Entry Level SS(MOD) rules proposed
Originally Posted by randy wilson View Post
I'm not against flat top pistons. Just trying to make sure the cars are in the low 6's or high 5's in 1\8th to make it interesting. That's mid to low 9's 1\4.
Ya........good luck with that...at these / those weights , a spec head, 6.20s and teens will be the norm.
Old 11-11-2014, 03:04 PM   #32
buzzinhalfdozen
Liked 11 Times in 8 Posts
Sean is correct, though I no longer run a stick car even with a 7 degree slider shifting without a clutch was a breeze. And without a dog in the fight I do agree that it would severely limit stick cars who would be relegated to base pressure tuning only. A lot of work and much more difficult than using counter weight. I complained many years ago while racing a stick car about the weight breaks, buttons ect. to deaf ears.
Joe Buchanan SS/BX 3117
Old 11-11-2014, 03:20 PM   #33
randy wilson
Liked 22 Times in 22 Posts
On the slider deal, you all may know more about shifting clutchless.We always used the clutch if we were in a clutch assisted class, so don't really know. I seen some people so bad at clutching, and shifting they picked up 2 and 1\2 tenths. We picked up just .06. That being said, this would be a must clutch to shift class, and put the driver back in the equation. It ain't rocket science, I can tell in one pass if someone is clutching or not. It ain't that hard. Then do what we did locally. Mount a roll bar camera, and make them back up there pass within .02 in full run, and .01 on 60ft. No need for counter wts. if you're using the clutch. Which is less expensive, a trick dual disc, or a single softloc? I don't know what the big deal is if everyone has a single disc clutch. It ain't like I have a trick dual, and you don't. I don't know that much about autos, but I doubt they would have an advantage. Now with NHRA wt. breaks, maybe. Again, if anyone hates the class, don't run it. Real simple. Probably never happen anyway, so calm down.
don,t have one
Old 11-11-2014, 03:25 PM   #34
randy wilson
Also, I beg to differ on the E.T. prediction of this class. We have already ran 6.29 109.67 in 1\8th which is in the 9.90 range in 1\4. And we were at 10.5# per cube, and clutched every gear with a 289 C.I. at 3040# And that was our first try. With an NHRA legal 750. Also, people locally could actually understand whats going on. First one there wins, heads up.
don,t have one
Old 11-11-2014, 08:16 PM   #35
Pvt Parts
Pvt Parts's Avatar
Originally Posted by Sean Marconette View Post
No disrespect, but that is not true. If the clutch is set correctly the ignition and clutch is not needed to shift a clutch assisted G-Force or Jerico.
I am at a loss on your clutch rules? Dual disc smaller than 10.5" clutches are common place in Stock. If you want to eliminate the stick guys than your current rules have done so. If you want to limit the clutches to maintain a limited budget class then state no Billet or ONLY stamped steel pressure plates allowed. Not allowing counterweight does not even make sense. Again your rules allow unlimited on the automatic transmissions and hand cuffing the stick racers.
Sean
Yes, the comparison is laughable.
Old 11-11-2014, 08:40 PM   #36
randy wilson
Ok. Explain. Let me in on the joke. Would a dual clutch and computer make you quicker? Yes? Would a vac pump build more power? Yes. Would a hand fabricated intake produce lower ET's? Sure. Would unlimited porting on the heads help performance? Of course. Would driving clutchless lower ET? Sure. But they are not allowed. That's what Comp's for. We're trying to make it affordable. All these things limit money spent. That was our goal. Remember, it's the same for everyone. Again, if not interested, don't run it. But it might just be a hit locally, and again people can understand it. Something very few do today as spectators.
don,t have one
Old 11-11-2014, 09:21 PM   #37
Rod Greene
Liked 242 Times in 81 Posts
The clutch rules don't make any sense. These rules must be proposed by some slush box racer.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 11-11-2014, 09:29 PM   #38
Pvt Parts
Pvt Parts's Avatar
My reference was the comparison between the rules for stick and automatic cars.
Restricted clutches = restricted converters (Lock up converters for one, are not addressed)
How is it that a stick shift driver is required to make 4 clutch assisted shifts (Which I've done hundreds of times) and an automatic driver who needs to move a handle once or twice is allowed a chip-assisted auto air shifter? (Rolls eyes)
I realize your honorable intent here but in the end, or perhaps from day one an experienced racer with adequate funding will dominate this class and you'll be right back where you are today with a new, expensive heads up eliminator.
Old 11-11-2014, 09:41 PM   #39
randy wilson
Could be right. No lock up converters should be addressed. That being said I ain't too bright on autos, so please explain. And I ain't being smart, I truly want to know. Is an auto better under these circumstances? We've also thought of only allowing clutch cars. I know Comp gives autos a 250# break, and their own index, and I've noticed both classes run realitively close to each other. I realize that's compared to a clutchless, but just my experience, and believe me when I say I realize we never had a Comp type clutch dialed in, but we only gained .06 going to a clutchless.
don,t have one
Old 11-11-2014, 09:59 PM   #40
Dick Butler
Liked 32 Times in 19 Posts
Seems like a Stick racer should offer an inexpensive Clutch /trans rule that would be a good starting point. No lock up converter is a good rule suggestion.
