Liked 48 Times in 13 Posts
Is it legal to put a fuel cell in the engine compartment of a super stocker?
Liked 33 Times in 16 Posts
I see nothing to prohibit it...see General regs 1.5.
Rich Taylor I/SA - 321 |
Liked 335 Times in 182 Posts
nothing in the rules says you cannot---BUT I will bet ya the first time you show up at the track they are gonna change the ruling to it has to be in a rear location.---FED 387
Sponsor
Liked 9 Times in 1 Post
And I quote from Bruce B from NHRA....."There is not a rule that says you can't, but it doesn't say you CAN".....Therefore you can't do it without getting an Ok.....Just decide if you want to ask permission or beg for forgiveness.
Plenty of fuel up front already...what's a little more? I would like to hear their reasoning if bounced.
Liked 370 Times in 101 Posts
Why would somebody need a fuel cell in the engine compartment ?
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
I ran a Chevy II at one time with a Hilborn injection system on alcohol with the fuel tank up front. Made sense with a belt driven pump. For a SS car I don't know other than carrying less fuel onboard and not having to overcome G-forces with a fuel column. Heck, I would even consider it on a Stocker if I knew it would fly by tech. How much fuel do we really need anyway...maybe two gallons at the most?
Liked 373 Times in 131 Posts
I've often wondered about the wording in the rulebook regarding fuel tanks and fuel cells.
Apparently a racer cannot alter the stock fuel tank for Stock Eliminator. (last sentence) However, the stock tank can be replaced by an aftermarket cell up to a maximum of 16 gallons. That's a big difference there. lol From the 2014 rulebook: GAS TANK Must be correct year, make, and model for car used, with stock fuel inlet and outlet locations. Must be in stock location; fuel line and pickup may be resized. Fuel cell permitted; maximum capacity 16 gallons. If fuel cell is used, OEM gas tank must be removed, and a firewall of minimum .032-inch aluminum or .024-inch steel must be installed to totally seal driver compartment from fuel cell. Trunk floor may be modified to accommodate fuel-cell sump. Where OEM gas tank is in the trunk floor, area occupied by OEM tank may be replaced with material equal to or heavier than OEM floor. If OEM gas tank is used, it must remain unaltered.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
I would love to run a 1 gallon tank up front.
It would save on the weight (and cost) of the fuel line ( 3 feet vs. 14 ft.) from rear to front. I have no problem adding 1/2 gallon (or so) of fuel between runs to top it off. Plus the 1 gallon tank weighs less than a 5 gallon one.
This is from the Super Stock section in the rulebook regarding gas tanks:
GAS TANKS Original stock-type fuel tank permitted; must be mounted in stock See General Regulations 1:5.location. Tank may be notched or sectioned for suspension clearance or to fit narrowed rear-frame unit. If filler neck is relocated into trunk, tank must have pressure cap and be vented to outside of body. Trunk must be completely isolated from driver compartment with firewall, minimum .024-inch steel or .032-inch aluminum. Accessory tank(s) prohibited. Fuel cell permitted, minimum 3- gallon, maximum 16-gallon capacity; may be mounted in trunk. Cool cans, fuel blocks permitted. Only one fuel cell or tank permitted.
