#31 | |
Liked 1,924 Times in 432 Posts
The GMPP 401 aluminum head is listed as an NHRA accepted replacement part for the early cast iron big block Chevy closed chamber rectangle port head. There is a HP penalty for using the aluminum replacement head. For example, we used them on a 69 Camaro 427/425, and that raised the HP rating from 425 to 435, so we had to add 80 pounds when running them in A/SA. There are certain parts allowed by NHRA as replacements for old castings that are both difficult to find, and expensive to buy. In the case of cylinder heads, a HP penalty is applied, it usually starts at 10HP. In the case of the 401 head, it is not allowing a different engine combination, it is allowing the 401 head to be used as a replacement for the OE head, with a HP penalty applied. The same applies to some heads for other makes. An aluminum replacement head is allowed for certain combinations, and it carries a HP penalty.
Alan Roehrich 212A G/S |
#32 |
Liked 56 Times in 31 Posts
Thank you for the clarification.
Thomas NHRA 1959 E/SA |
#33 |
Liked 11,004 Times in 2,263 Posts
Ken you have a very good car, but a 70 Nova should be 402/ 395 iron, or 402/ 405 aluminum.
#34 |
Liked 18 Times in 8 Posts
#35 |
#36 |
Liked 664 Times in 187 Posts
Definatley some very fast 396's out there!!
I think A/S will be cool this year too! Hopefully with the new cars in there own classes it should bring back some old school cars. .
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#37 |
Liked 10 Times in 1 Post
I went 9.95 in Dan Fletchers car with that combo in the semis in Pomona a few years ago. Unfortunately it was heads up and Jimmy DeFrank went 9.74. It was a 375 h.p. rating at the time but I'm sure Jimmy can still go 9's .
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC |
#38 |
I think Jimmy, Joe, and Lance can all go 9's in B/SA.
#39 |
Liked 13 Times in 2 Posts
well if the cars are built with NHRA specs, I would be surprised any of them could
#40 |
Liked 30 Times in 17 Posts
