Old 11-23-2014, 12:45 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Anti Roll Bar and Eibach Drag Launch Springs
For the Mustang 5.0 stocker - If I installed the bolt-in anti roll bar do I have to ditch the eibach drag launch rear springs and go to the same left and right spring rates? I let all the air out of the air bag and scaled the car and have even weight on both rear tires at full race weight. Oh yea and I ditched the rear factory sway bar also.
'65 Mustang SS/L & L/SA
Old 11-24-2014, 10:52 AM   #2
TurboBuick6
Default Re: Anti Roll Bar and Eibach Drag Launch Springs
I would contact Team Z out of Taylor, MI. They are the Fox Body guru's.
TurboBuick6 is offline   Reply With Quote
Old 11-24-2014, 10:58 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Can't say what's what yet as the car hasn't been to the track yet. Using Team Z uppers, Southside lowers and stock GT springs...I elected to leave the factory sway bar on for the first attempt.
Rich Taylor
I/SA - 321
Old 11-24-2014, 01:05 PM   #4
Mike Washington
Liked 6 Times in 2 Posts
To the Original Poster:
When using an Anti Roll bar, The spring rates should be even. The ARB is now controlling Body Roll, Not the Springs
I would suggest not using the South Side and The Team Z uppers together. Both of those bars are trying to accomplish the same goal, changing the suspension geometry. I would use one or the other. The Team Z bars are what I use in my car. I have an NMRA Coyote Stock car that makes 450rwhp and weighed 2700lbs and went a 1.29 60 with Team Z products.
Mike Washington is offline   Reply With Quote
Old 11-24-2014, 03:33 PM   #5
Thanks for posting this, Mike
Now I don't have to be the bad guy again.
IC ..too high and too far back, besides being way over kill for O/SA
Old 11-24-2014, 04:24 PM   #6
HandOverFist
But will it work? I can easily swap lowers if need be. I also know the car won't be near as light as Mike's and nowhere near the hp.
Rich Taylor
I/SA - 321
Old 11-24-2014, 04:42 PM   #7
Probably will.
Probably would work with just a lot of ballast and an air bag as well.
At least you're supporting the aftermarket this way. ;-)
Old 12-12-2014, 11:15 AM   #8
James Gorski
When you use the anti-roll bar you will need the same spring rate on each side of the car. Team Z offers some nice parts for stock location springs in a few different spring rates. I use coil overs with 110# springs with the anti-roll bar with zero pre-load in the bar.
James Gorski is offline   Reply With Quote
Old 12-12-2014, 12:01 PM   #9
SSDiv6
Stock Eliminator requires an OEM configuration rear suspension, therefore, coil overs are not legal in the class.
Old 12-12-2014, 12:23 PM   #10
James Gorski
Thank you. I understand that was just using it as a reference in spring rates.
