Old 11-26-2014, 06:02 PM   #1
Marvin Robinson
Marvin Robinson's Avatar
Default Oil pan and timing cover gaskets
I'm almost done with my new Olds 455 engine, any recommendations for oil pan and front timing cover gaskets? (Cork vs rubber) Should I use gaskets on both sides of the pan scraper, one side with Ultra Grey on the other, or just a lot of Ultra Grey on both sides? .
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
Old 11-26-2014, 06:24 PM   #2
SSDiv6
Default Re: Oil pan and timing cover gaskets
Originally Posted by Marvin Robinson View Post
I'm almost done with my new Olds 455 engine, any recommendations for oil pan and front timing cover gaskets? (Cork vs rubber) Should I use gaskets on both sides or the pan scraper, one side with Ultra Grey on the other, or just a lot of Ultra Grey on both sides? .
Use the Olds 350 Diesel oil pan gasket which has a metal core between the scraper and oil pan. Then use Ultra Grey between the block and the scraper/oil pan. Also use Ultra Grey on the timing cover.
SSDiv6 is online now   Reply With Quote
Old 11-26-2014, 07:06 PM   #3
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Oil pan and timing cover gaskets
Marvin,
I use cork on one side & scraper with Ultra gray on both sides, on the other... Attach the scraper to the block first with a good thin bead , hold down over-night with oil pan bolts ...Make sure you rotate crank to be sure you have enough clearance & nothing is hitting ? Also, trim any extra Ultra gray stuff away and do the top edge of scraper and tighten down pan with another good bead of Ultra ... This is what I do on my Pontiac engines... Hope this helps...
Dave Ribeiro 1033 STK
Old 11-26-2014, 08:21 PM   #4
Liked 1,909 Times in 427 Posts
Dave's method is similar to mine, although I use red hi temp RTV. The suggestion to use the metal core cork gasket is a good one as well.
On the timing cover I always use a gasket, and install it dry first to set my cam end play, and then use a super thin layer of the same red hi temp RTV for final assembly.
Old 11-28-2014, 02:45 PM   #5
Jim Kaekel
Liked 535 Times in 110 Posts
I also use the Fel-Pro Olds 350 Diesel pan gasket. Works very well.
Jim Kaekel 3836 STK
Old 12-02-2014, 06:06 AM   #6
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I believe the part # is Fel-Pro OS30471C
