Old 11-27-2014, 01:18 PM   #41
jcw31
Liked 6 Times in 6 Posts
Default Re: Spark plugs
Billy how much do you attribute the difference to them possibly being a different heat range than an iridium plug? A friend had a zz502 crate when we changed from rapidfire [a multiple heat range]
to ngk copper the car also slowed down. The interchanges between different companys dont always match correctly.Also the rapidfires while I agree is a very good plug also has a v tipped ground strap which helps.
Joe
jcw31 is offline   Reply With Quote
Old 11-27-2014, 02:28 PM   #42
Ed Wright
Ed Wright's Avatar
I had a box sitting on the work bench in my dyno bay, nearly full of new or nearly new NGK spark plugs we had to pull out of customers cars to stop WOT misfires. They always said "I never heard it miss like that!" I would tell them they never stood near the tail pipes, while it was running wide open, in a tin building before. And that it needed fixed before I could tune it. Not all NGKs that came through there had a misfire problem, but I don't remember having to replace another brand of new plugs like that. About filled that box up before we shut the shop down.
Ed Wright 4156 SS/JA
Old 12-02-2014, 02:30 PM   #43
Belvedere II
Originally Posted by Alan Roehrich View Post
Smokey Yunick once told me "if you knew how many times your engine actually misfired, you'd be so pissed off, you'd never start it again". What a lot of people don't understand is that most of the noise you hear is from air flow, not actual combustion. Yes, you can hear a dead cylinder easily. But as Smokey once demonstrated, and backed up with data, what you can't hear is how often each cylinder has a partial misfire. I don't think you can solve that problem with trick spark plugs, or trick spark plug wires. I do think you can make the problem worse with the wrong spark plugs. I don't think any one company makes the best plug, or the best plug for all applications.
My readings of information from Jacob's Electronics indicates they believe they have the best solution to that common problem of misfiring cylinders. From their website:
High Performance Ignition Packs
Energy Paks are not to be confused with OEM/factory computers or simple add-on hot spark or multi-spark ignitions. Jacobs' computer controlled ignitions modify spark output in response to changing environment and running conditions. (US Patent #3,827,418). By tailoring spark voltage, duration and phase angle for each cylinder on every power stroke, all Jacobs Electronics' computer-controlled ignition systems are guaranteed to improve performance, gas mileage, engine life and lengthen intervals between tune-ups.
I've not run one of their ignition packs but did install their version of a rev limiter in my first car. Currently have a 6AL for that purpose.
Belvedere II is offline   Reply With Quote
Old 12-04-2014, 01:31 PM   #44
69ss/rs
Has anybody tried the E3-spark plugs in a race engine. I know they made a big improvement in my street cars.
69ss/rs is offline   Reply With Quote
Old 12-04-2014, 02:36 PM   #45
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I'm interested in this too. According to what I've read/heard they have been working on a plug for nitro engines.
My next order from Summit will include a set of the RapidFire plugs recommended by Alan previously in this thread. I'll see how they burn in my 302 Ford.
Dale
Old 12-04-2014, 04:21 PM   #46
rick978
rick978's Avatar
we are trying the e3 plugs now in a fox body and so far no issue and car is running the best it has they are a little pricey though
rick978 is offline   Reply With Quote
