Old 11-29-2014, 10:06 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default handheld air "inflator" for use in lanes
I see racers using a handheld air "inflator" that is shaped somewhat like a drill. Does someone have experience with a handheld unit for adding a last minute 1/4 pound of air?
Larry Woodfin 471W
Old 11-29-2014, 10:25 PM   #2
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: handheld air "inflator" for use in lanes
The search feature is your best friend! ��
http://classracer.com/classforum/showthread.php?t=23887
Old 11-29-2014, 11:45 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I've got one of the Bickel compressors Larry. Be sure to test it beforehand on your tires...it won't actuate the valve in some stems. Worked fine for airing up the air bags on the truck, but when I got to the track I could not air the tires on the car. Guess who didn't bring the air tank that day? Took everything I had not to heave it across the pits lol...my air tank now goes along everytime if only for the ride. I really can't recommend the Bickel inflator. What we should be using if there is a definite need... https://www.biketiresdirect.com/search/co2-inflators
Rich Taylor
I/SA - 321
Old 11-30-2014, 12:51 AM   #4
Robbie Draughon
Liked 29 Times in 5 Posts
I use a craftsman 18v from Sears. Batteries interchange with my drill. I've had it for a few years with no problems.
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
Old 11-30-2014, 08:47 AM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: handheld air "inflator" for use in lanes
I've always used a little manual foot pump. It's smaller, lighter, less expensive and plenty good for that 1/4 - 1/2 lb by hand. The gauge is irrelevant since I double-check with my regular tire gauge. The plastic chuck is pretty cheap, but I eventually replace it with a better hose & metal chuck. You can find them anywhere - Harbor Freight, Walmart, etc. & cheap enough to have a spare!
As small as it is, I have been warned a couple of times over the years about keeping it secured in a box to keep it from being a "projectile" in case of an accident.
http://ecx.images-amazon.com/images/...500_AA300_.gif
LOCOMOTION Racing
Old 11-30-2014, 10:15 AM   #6
Dragsinger
Myron, I like the manual idea.
Larry Woodfin 471W
Old 11-30-2014, 12:58 PM   #7
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Cool Re: handheld air "inflator" for use in lanes
I too have used the foot pumps, till last season when I "borrowed" my sons Blackburn Airtower 2. Its a cadillac of pumps. High quality pieces throughout 140LB air setting, and is about 250% more efficient than a foot pump. Wedges in just fine behind the seat of the truck, or in the bed of course next to the lawnchair and cooler. I ordered one for myself.
In any event you will be living the GT/Truck dream next season if your stuck in the lanes for 2.5 hours due to a oil down, as the sun and temp come crashing down, calmy biding your time in your comfy lawn chair, enjoying a cold soda, checking weather, adding air if you need it......glad you didn't build a anteater car!
Make sure to secure your additional ballast.
Eric
Eric Merryfield 1883 STK
Old 11-30-2014, 02:00 PM   #8
Dragsinger
Eric, Thanks for the note. gave me a smile. I will check into your pump recommendation.
I have an update that will most likely be the route I take. The last five bracket cars we built used the "air armed" on-board compressor. It is a very sweet piece, we use it for shifter and starting line controller. It also is completely capable of topping off tires. There will be less than 3 pounds between the "air armed" and a small C02 bottle so what ever
With the Super 10 build I am considering each component for weight. The original plan was to run "B" which will be 3090 pounds with driver. However, because I am a , err, well, "large man" the 3090 pounds with driver may not be possible.
Of course, I can race it overweight and that is an OK option. But the better option is changing to "C" which will be 3372 pounds. It will require some ballast for so that gives the option to place weight as needed.
Larry Woodfin 471W
Old 11-30-2014, 07:37 PM   #9
340Cuda
Liked 805 Times in 341 Posts
Is Miller the exclusive dealer for the Air Armed compressor?
http://www.miller-racecars.com/build...5db8855325cabf
Old 11-30-2014, 08:15 PM   #10
Dragsinger
K & R sells the air armed
Larry Woodfin 471W
