If you are a natural FS/A class car can you move down to FS/B
Thanks Bo Kenney
Bo Kenney |
If you can take the supercharger off.
FS/A: · Index: 10.10 · Supercharged entries only o Cars with a 2.3L Eaton supercharger must weigh a minimum of 3,400 lbs. o Cars with a 2.9L Whipple supercharger must weigh a minimum of 3,550 lbs. FS/B: · Index: 10.35 · Naturally Aspirated entries only o Entries up to 400 CID must weigh a minimum of 3,250 lbs. o Entries up to 430 CID must weigh a minimum of 3,350 lbs. o 2011 Dodge V10 entries must weigh a minimum of 3,500 lbs.
Dan Wilson, STK3171, K/SA |
I think he it taking about the new classes!
STOCK Class Weight Break Index FS/A 6-6.49 index 9.7 FS/B 6.50-6.99 index 10.00 I would sure think you can move. If we are all stuck in our Natural class that would be ruff.
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
I don't see why you wouldn't be able to. There's already precedent for the supercharged cars to run either a 6.0 or 6.5 lb. class. Skillman's CJ ran in the "old" AA/SA @ 6.5 lbs all the time. Plus, the general rule for Stock is that you can move up/down one class from your natural fit.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
Liked 228 Times in 70 Posts
You are always allowed to move up or down one class from your natural class. The exception would be if a cars natural class would fall in a lower number than the classes available. For example, for FS cars if the natural weight break would be 5.5-5.99, this car would only be allowed to run 6.00 weight break class. Another example, a non FS car that is a weight break of 7.0-7.49, would only be allowed to run AA.
OK the new classes.
You can add more weight to go a class down. STOCK Class Weight Break Index FS/A 6-6.49 9.7 FS/B 6.50-6.99 10 FS/C 7-7.49 10.3 FS/D 7.50-7.99 10.6 FS/E 8-8.49 10.95 FS/F 8.50-8.99 11.2 FS/G 9-9.49 11.35 FS/H 9.50-9.99 11.5 FS/I 10.00-10.49 11.65 FS/J 10.50-10.99 11.8 FS/K 11.00-11.49 11.9 FS/L 11.50 or more 12
Liked 2,359 Times in 557 Posts
I guess there will be new classes for the Shootouts this year?
Yes the shoot out classes will be :
SO/A SO/B SOA: · Index: 10.10 · Supercharged entries only o Cars with a 2.3L Eaton supercharger must weigh a minimum of 3,400 lbs. o Cars with a 2.9L Whipple supercharger must weigh a minimum of 3,550 lbs. SOB: · Index: 10.35 · Naturally Aspirated entries only o Entries up to 400 CID must weigh a minimum of 3,250 lbs. o Entries up to 430 CID must weigh a minimum of 3,350 lbs. o 2011 Dodge V10 entries must weigh a minimum of 3,500 lbs. You will be allowed to run SOC with 1 coil removed. Dan
Dan Wilson, STK3171, K/SA Last edited by Dan Wilson; 12-03-2014 at 10:08 AM. |
Liked 325 Times in 50 Posts
New SO class. How about SO/N 70 or older car, factored hp @ 8.25 lbs. 11.10 index no ahfs. Old time shoot out.
Jeff Teuton 4022 STK |
Liked 24 Times in 13 Posts
Count me in Jeff!
Mike Keener A/S B/S C/SM |
