Old 12-01-2014, 07:43 PM   #1
treessavoy
Liked 4 Times in 4 Posts
Default Max Wedge
If I decide to move to SS can my Max Wedge use the same style intake design as the SS/AH cars, if so, what is the offset for the carbs?
Thanks,
JimR
oop's, mgmt....you can move this to Tech.
Jim Rountree
Old 12-01-2014, 09:39 PM   #2
Darcy Clarke
Liked 529 Times in 36 Posts
Default Re: Max Wedge
Hi Jim
I had asked NHRA the same thing for my current SS project and I was told that the carbs can have the primary bores inline.
Darcy Clarke
6254
A/SA SS/JA
Darcy Clarke is offline   Reply With Quote
Old 12-02-2014, 02:13 PM   #3
James L Miller
Liked 25 Times in 16 Posts
Rh
Mopar 2 Ya!
Old 12-02-2014, 02:38 PM   #4
treessavoy
Originally Posted by Darcy Clarke View Post
Hi Jim
Darcy Clarke
6254
A/SA SS/JA
Thanks Darcy,
Are you building a Hi or Low comp. motor?
Jim Rountree
Old 12-02-2014, 03:41 PM   #5
Darcy Clarke
Hi Jim
I built the high compression, it's been a real challenge. Which version are you building?
Darcy Clarke
6254
A/SA SS/JA
Old 12-02-2014, 05:22 PM   #6
treessavoy
Hi Jim
Darcy Clarke
6254
A/SA SS/JA
Darcy,
I'm pondering building the low comp. It's a '64 Savoy.
JimR
Jim Rountree
Old 12-02-2014, 10:00 PM   #7
Barnstorm
Barnstorm's Avatar
What class were you thinking?
Old 12-02-2014, 11:00 PM   #8
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Hi Jim
Darcy Clarke
6254
A/SA SS/JA
Hi Darcy, Just wondering where you had trouble as these are pretty simple motors for the most part, I'm thinking the mani would be the most challenging part as well as hood clearance.
Old 12-02-2014, 11:26 PM   #9
Paul Precht
Originally Posted by treessavoy View Post
Darcy,
JimR
Jim, the low comp is at 395HP compared to 415 for the high comp. If you run the car in SS/EA that's 160lbs difference.
Old 12-02-2014, 11:52 PM   #10
Darcy Clarke
Hi Paul
The intake is a challenge. Have you built a SuperStock Wedge?
Darcy Clarke
6254
A/SA SS/JA
