Old 12-05-2014, 11:03 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Which is it......battery or ballast ???
Can a battery be properly secured in the trunk area without being wired for use and not be considered ballast weight ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 12-05-2014, 11:30 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Which is it......battery or ballast ???
run some cables to "nowhere" problem solved---FED 387
Old 12-05-2014, 12:00 PM   #3
Rusty Davenport
I respect and appreciate your answer but its really not "the" answer. What you are saying now will require installation of rear cut off switch doesnt it ??? I just want a battery for weight when the weight box has reached maximum allowed ballast. Does the battery become ballast or is it still considered a battery. It sounds like an Eric Holder-Obama issue but it really isn't. :-)
Old 12-05-2014, 12:18 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
If it's not wired, it's ballast and has to be secured by 1/2 inch bolts with welded nuts. That would be through the battery, not a hold down strap. Straps are prohibited. Why not just wire it and have extra juice to go with the extra weight? If they are wired in series with the second battery linked to the first, you don't need a second cut off switch.
EDIT: Is battery A up front or in the trunk?
I'm not a tech.
Dale
Old 12-05-2014, 12:25 PM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I would nix the battery idea and just secure some extra permanent ballast. You can then add/subtract with your adjustable ballast.
Rich Taylor
I/SA - 321
Old 12-05-2014, 12:39 PM   #6
Bill Harris
Liked 26 Times in 13 Posts
If you wire them in series your going to have 24V and probably a fire somewhere. They need to be in parallel. If you have a battery in the trunk you have to have a master cutoff switch in the positive side of the circuit at the rear of the car so that means two high current cables between the front and rear, one for positive-positive between the batteries and to the switch, and another from the switch to the rest of the electrical system. Negative (aka "ground" side can use the chassis as the conductor on both batteries. It is a it of work but probably worth it in the long run. You can always remove the rear battery to lose weight if needed. Note that both batteries are supposed to be the same size and weight. I seem to recall some disqualifications recently for having a fake (hollow) battery in the front.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 12-05-2014, 01:16 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
X2. There is no real need for two batteries if you are charging it between rounds.
Mike Pearson 2485 SS
Old 12-05-2014, 01:17 PM   #8
FireSale
FireSale's Avatar
That's what I meant. Got my words "crossed up"...
+ to +, - to -
Dale
Old 12-05-2014, 02:22 PM   #9
Liked 10,837 Times in 2,252 Posts
Don't forget the rear firewall if battery is in the trunk.
Old 12-05-2014, 08:17 PM   #10
FED 387
Unless the rules have changed better check on this tho " if you are not running a fuel cell but still are using a "stock" gas tank you can use a gas tank shield located between the top of the tank and the trunk floor as an approved safety device-it is not considered disguised ballast!! Now don't go putting a 1 inch piece of plate steel but you can use either steel or aluminum plate to do this "thin" gauge like 1/4-3/8 inch depending on how much weight you need ---FED 387
