Old 12-08-2014, 07:24 PM   #21
Jim Caughlin
Liked 805 Times in 245 Posts
Default Re: steel or aluminum driveshaft?
As they say on television, "Your results may vary". All I can say is that a low HP combinations like mine, particularly spinning the driveshaft up to 9200 RPM at the finishline should be the most likely candidate for improvement and I got zip. For what it's worth, this was a back to back test so I'm pretty confident of my results. Funny thing is that if I was going to start over, I would buy the lightweight parts regardless. I know in my mind that it has got to be better even if the performance results don't show. At the very least, the weight reduction results in less unsprung weight and allows more static ballast over the rearend.
Jim Caughlin
SS 6019
Jim Caughlin is online now   Reply With Quote
Old 12-08-2014, 09:25 PM   #22
Ed Wright
Ed Wright's Avatar
I always A-B-A stuff like the driveshaft at the track, same day. I did not the spool. Spent that money, and the lightened ring gear, figuring it HAD to be worth SOMETHING. But it was less than 5 lbs lighter than the lightened Strange steel spool. Mine only runs 8500 in the lights.
It ran the weather station predictions equally with both spools.
Ed Wright 4156 SS/JA
Old 12-08-2014, 10:26 PM   #23
Mark Ugrich
Liked 71 Times in 38 Posts
I've often wondered if the reason that lightened axles,driveshafts,etc. don't show an increase in performance is because of the short distance we run.In other words if you made the same weight saving modifications to a Bonneville salt flats car, it has a longer period of time to effect the car.Of course they don't measure E.T.and I could be wrong also.
Old 12-08-2014, 10:51 PM   #24
Ed Wright
Ed Wright's Avatar
The diameter on the weight difference makes a difference. 5lbs on a spool, or an even smaller diameter driveshaft is all that much change in inertia. Five pounds on a 32" tire, for instance, is a different deal. I have a pair of Goodyear radials, same size as my MTs, but five pounds per tire difference. Hook just as hard. Consistent four hundredths slower than the Mickys. Three of it in 60'. I can't imagine how it could be anything but weight.
I spent money to get six more pounds off a crankshaft during a freshen up also. Saw nothing. A very low hp engine? Maybe.
Old 12-09-2014, 09:56 AM   #25
flash
Liked 6 Times in 5 Posts
can anybody see a reaction time difference with changing to light weight driveline componets ? I would think it would be very small if you could gauge it at all.
flash is offline   Reply With Quote
Old 12-09-2014, 10:59 AM   #26
SSDiv6
Liked 1,600 Times in 583 Posts
Like it has been shared on this discussion by many, there are lots of variables involved. One of the main gains that many have seen is switching to lighter rear wheels.
Old 12-09-2014, 11:32 AM   #27
Ed Wright
Ed Wright's Avatar
Yeppers, or rear tires.
Old 12-09-2014, 11:48 AM   #28
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
What are the wights of the this 3, 9x30 radials?
Hoosier
M/T
GOOD YEAR
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 12-09-2014, 11:56 AM   #29
buzzinhalfdozen
Liked 11 Times in 8 Posts
Can't comment on any performance increases, I've always bought the lite stuff. On a new build I'd say pay the extra money and go lite, not sure if I'd purchase "extra" lite components trying to improve performance. In my opinion engine upgrades, convereter, gearing would be a better place to spend that money.
Joe Buchanan SS/BX 3117
Old 12-09-2014, 12:26 PM   #30
Ed Wright
Ed Wright's Avatar
Hoosier
M/T
GOOD YEAR
Glen, I don't use 9" tires. I have no idea.
