#31 |
Liked 333 Times in 180 Posts
MEXJOE---- about 22.7---23 pounds per tire depending on the brand--FED 387
#32 |
Liked 126 Times in 20 Posts
Use aluminum
Tim Worner SS 1747 |
#33 |
the use of JUST a steel or aluminum driveshaft alone is not going to give you any significant reduction in ET--- however when used in conjunction with many other "performance/lightweight" parts the overall performance of a particular vehicle should improve. It all depends on the parts selected and the individual vehicle-- some will see improvements while others may maintain the status quo or its even possible that your performance "may" not be as good as before---- it also might just contribute to parts longevity.--there is no firm answer to this question--- in some instances steel is the way to go while in other situations an aluminum driveshaft is the answer--you just have to experiment and observe what a " quick" similar classed vehicle is using and how your performance compares to that one--- FED 387
#34 |
If nothing else, I think it may soak up some shock to the gears in a Trans brake or stick car.
And a steel spool may be enough more rigid to improve gear set life.
Ed Wright 4156 SS/JA |
#35 |
I've won and lost by .003. If you are in this game to win, you do it all. Everything!
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#36 |
Liked 520 Times in 132 Posts
Here's one answer I got a couple years ago about lightweight parts!
We didn't see anything. I remember Joey Wilkes did everything. Gun drilled MW 40 spline and all. It slowed down...Ask him about it. It was kinda funny at the time, ( Even he was laughing) __________________ Jeff Niceswanger 3740
#37 |
Liked 2 Times in 2 Posts
Steel is ugly. Aluminum is pretty.
#38 |
Liked 780 Times in 194 Posts
#39 |
Liked 30 Times in 17 Posts
You never know when it might make the cover.
