Old 12-09-2014, 01:24 PM   #31
FED 387
Liked 333 Times in 180 Posts
Default Re: steel or aluminum driveshaft?
MEXJOE---- about 22.7---23 pounds per tire depending on the brand--FED 387
Old 12-09-2014, 03:47 PM   #32
tim worner
Liked 126 Times in 20 Posts
Use aluminum
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 12-09-2014, 04:44 PM   #33
FED 387
the use of JUST a steel or aluminum driveshaft alone is not going to give you any significant reduction in ET--- however when used in conjunction with many other "performance/lightweight" parts the overall performance of a particular vehicle should improve. It all depends on the parts selected and the individual vehicle-- some will see improvements while others may maintain the status quo or its even possible that your performance "may" not be as good as before---- it also might just contribute to parts longevity.--there is no firm answer to this question--- in some instances steel is the way to go while in other situations an aluminum driveshaft is the answer--you just have to experiment and observe what a " quick" similar classed vehicle is using and how your performance compares to that one--- FED 387
Old 12-09-2014, 04:48 PM   #34
Ed Wright
Ed Wright's Avatar
Originally Posted by tim worner View Post
Use aluminum
If nothing else, I think it may soak up some shock to the gears in a Trans brake or stick car.
And a steel spool may be enough more rigid to improve gear set life.
Ed Wright 4156 SS/JA
Old 12-09-2014, 07:13 PM   #35
Pvt Parts
Pvt Parts's Avatar
I've won and lost by .003. If you are in this game to win, you do it all. Everything!
Old 12-09-2014, 10:43 PM   #36
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Here's one answer I got a couple years ago about lightweight parts!
We didn't see anything. I remember Joey Wilkes did everything. Gun drilled MW 40 spline and all. It slowed down...Ask him about it. It was kinda funny at the time, ( Even he was laughing)
Jeff Niceswanger 3740
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 12-09-2014, 11:04 PM   #37
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Steel is ugly. Aluminum is pretty.
rickseeman is offline   Reply With Quote
Old 12-10-2014, 02:37 PM   #38
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Depends on the painter.
Old 12-10-2014, 02:45 PM   #39
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
You never know when it might make the cover.
Pedigo Perf is offline   Reply With Quote
