Old 10-30-2014, 07:45 PM   #11
Liked 1,908 Times in 427 Posts
Default Re: Alum Radiators for stockers ....2015
I've had good luck with Northern Radiator. They also have really nice kits with cooling fans, mounted on shrouds, with relays, that fit the radiator and the vehicle.
Old 10-30-2014, 10:16 PM   #12
Run to Rund
Liked 54 Times in 27 Posts
You might also check radiatorbarn.com
I have bought both copper and aluminum/plastic radiators from them with good results. Their one core aluminum cools better than the 3 core copper!
Old 10-31-2014, 10:48 AM   #13
Jim Bailey
Liked 584 Times in 94 Posts
Thumbs up Re: Alum Radiators for stockers ....2015
Thanks guys for all the great input and leads! I just didn't want to run out and purchase a double whammy, throwdown, aftermarket, fabricated alum tank radiator, only to have an inspector tell me that it isn't " stock appearing". Plus I'm a little partial to having my car look correct. Thanks again. - JB -
Jim Bailey is offline   Reply With Quote
Old 10-31-2014, 12:19 PM   #14
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Looks like I'll be putting my beater back together very soon. Will help to lose a few pounds from out on the front end. I don't think there will be a generic part for mine, but I'll come up with something.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 10-31-2014, 06:06 PM   #15
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
A couple years ago was checking on radiators,they could get me all aluminum,the tanks looked like the tanks on copper/brass radiators,still had the grooves that stiffen them core looked like copper/brass core,looked identical except the tanks and core were welded together,if was'nt for the welds could have painted it black and passed it off as copper/brass radiator, was $80-100
I guess now would be legal
Mike Taylor 3601
Old 12-10-2014, 09:00 PM   #16
brent flynn
brent flynn's Avatar
Originally Posted by HandOverFist View Post
Like I'm going to run out and buy one of these for the Camaro lol... http://www.jegs.com/i/Be-Cool-Radiat...61#moreDetails
A little more sensible... http://www.jegs.com/i/Champion+Cooli...CC370/10002/-1
What is the actual rule? I was thinkin of something like this...would have to fab bottom brackets, and the top one, could be hid under the shroud bracket. It would be somewhat lighter than the champion 3 row, you mentioned above... what's your thoughts?
http://www.jegs.com/i/JEGS-Performan...oductId=752961
Old 12-10-2014, 11:32 PM   #17
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Myself I would prefer not to do any fabricating...I would probably burn holes in it lol. Ran across this all aluminum unit on ebay for the Mustang which came with two fans/mounting hardware, cap and drain petcock for $149 shipped...I couldn't resist. It isn't flimsy in the least.
Rich Taylor
I/SA - 321
Old 12-10-2014, 11:41 PM   #18
Don Anderson
Liked 25 Times in 9 Posts
Kind of what I figured. Ought to work well in the O/SA build.
Works great!! Cools better than the two core OEM one.
Don Anderson
M/S #5891
Don Anderson is offline   Reply With Quote
Old 12-11-2014, 12:20 PM   #19
Steve Hagberg
Jim: Try Classic Industries part number MB2353A. It's nearly identical to the correct radiator for the '64-'65 Hemi cars. I have one in my '64 Plymouth now. I believe it's made by US Radiator.
Steve
Steve Hagberg is offline   Reply With Quote
Old 12-11-2014, 03:44 PM   #20
GTX JOHN
I wonder if we can put a cross flow radiator in instead of stock up and down flow?
I understand they are more efficient..........Anyone have an opinion?
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
