Old 12-12-2014, 02:51 PM   #31
Terry Knott
Terry Knott's Avatar
Liked 21 Times in 3 Posts
Default Re: Alum Radiators for stockers ....2015
For what it's worth.......when I had the crate motor in my car my aluminum radiator filled with water weighed 1.5 lbs. less than my stock 340 radiator filled with water. PLUS.......my stock radiator cooled much better.
Terry Knott is offline   Reply With Quote
Old 12-12-2014, 08:53 PM   #32
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Brent - I weighed both radiators today and was surprised...the factory one is 14 pounds and the new one is 11 pounds.
Rich Taylor
I/SA - 321
Old 12-12-2014, 11:47 PM   #33
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
And remember that the water will add a lot of weight (1 lb/pint).
Old 12-12-2014, 11:54 PM   #34
brent flynn
brent flynn's Avatar
Originally Posted by HandOverFist View Post
I'll weigh the stock vs the new radiator tm and let you know the difference.
Great! Im runnin a 4 row right now(brass)...so its pretty dang heavy...and runnin more liquid than i need...
Old 12-12-2014, 11:56 PM   #35
brent flynn
[QUOTE=HandOverFist;455119]Brent - I weighed both radiators today and was surprised...the factory one is 14 pounds and the new one is 11 pounds.[/QUOTe
Were you running a 3 row? or 4 row? before you changed to alum...
Was this the camaro radiator that you weighed?
Old 12-13-2014, 12:02 AM   #36
brent flynn
[QUOTE=Travis Miller;455084]According to Bruce Bachelder, it does not have to be an exact replacement. A cross flow can even replace a top tank or it can be the other way around.
This new rule is about NHRA allowing Stock racers to use an aluminum radiator to replace the hard or impossible to find OEM one. It is not about who can push the rule by installing the smallest aluminum radiator that can be found. That would just raise a red flag for us to take a harder look at the entire car.[/QUote
I wonder if any bracket fabbing is allowed?
Old 12-13-2014, 04:40 AM   #37
HandOverFist
[quote=brent flynn;455134]
This was the Mustang radiator Brent. Not certain what was factory for these cars in 1990, but this replacement is a 3-row. The Camaro radiator is in great shape and I'll never change it unless it develops problems.
Here's one that should bolt right in your car Brent with no mods... http://www.ebay.com/itm/271450398612...%3AMEBIDX%3AIT
Rich Taylor
I/SA - 321
Old 12-13-2014, 08:54 AM   #38
Mike Savelle
Liked 7 Times in 5 Posts
Talking Re: Alum Radiators for stockers ....2015
you do know that the hoses are reversed on a Ford , might make it hard to install in the Camaro..
Mike Savelle is offline   Reply With Quote
Old 12-13-2014, 12:33 PM   #39
ken robinson
Liked 224 Times in 87 Posts
Is there a big price differance between champion and be cool radiators . Never really looked at any of them in the bracket cars when in the lanes , is there a quality issue where .I like the champion small 3/4 core 2 row . For the camaro
Old 12-13-2014, 09:52 PM   #40
HandOverFist
Here it is in the '90 Mustang...fits fine even with the tweaked radiator support.
Rich Taylor
I/SA - 321
