Old 12-21-2014, 11:54 PM   #1
Tim Ellis
Liked 7 Times in 6 Posts
Default Reaction time difference, bias ply vs. radial slick
Anyone tested reaction times on their car bias ply slicks versus radials? Naturally one would assume the radials would be quicker because of more air pressure and a stiffer sidewall,no wrinkle, but how much??? Remember I'm talking R.T not E.T. thanks
Tim Ellis is offline   Reply With Quote
Old 12-22-2014, 10:43 AM   #2
Joe DeMarzo
Liked 120 Times in 11 Posts
Default Re: Reaction time difference, bias ply vs. radial slick
Tim, I saw nothing you could measure in RT, I guess it depends on how much air pressure you run in the bias tires. The travel distance to hit the tree is minimum so it can't be that much if you are consistent in your launch. The 60 ft's are about .03 to .04 slower depending on the time of year. Hope it helps.
Joe DeMarzo 1317 STK
Old 12-22-2014, 10:56 AM   #3
Ed Wright
Ed Wright's Avatar
With my car, I gave up using biased tires to help slow it down. I'm not good enough to adjust my driving for the change.
A lot of added weight effects mine too. Took 200 lbs out for first round of class at Indy, went red. Put it back in for eliminations. Thought it was a fluke, until I duplicated it later testing. Guess I need to buy a Just in Time button. Don't have any spacers to pull off my Biondo button.
Ed Wright 4156 SS/JA
Old 12-22-2014, 01:37 PM   #4
Pvt Parts
Pvt Parts's Avatar
Easy to do with a third pedal Ed.
Old 12-22-2014, 02:16 PM   #5
Ed Wright
Ed Wright's Avatar
Sure be a lot more fun. I'm not up to the extra work.
Old 12-22-2014, 06:14 PM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Keeps your joints limber.
Old 12-22-2014, 08:30 PM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Thumbs up Re: Reaction time difference, bias ply vs. radial slick
http://classracer.com/classforum/ima...ons/icon14.gif
Old 12-22-2014, 09:29 PM   #8
Tim Ellis
Thanks Joe and Ed. Anyone else ?
Old 12-22-2014, 11:55 PM   #9
7423
Zero RT difference between bias @15 psi and my radials @ 24psi. Radials are .10-.15 faster ET in my 12 second car. Your mileage may vary. .
7423 is offline   Reply With Quote
Old 12-23-2014, 09:09 AM   #10
Ed Wright
Ed Wright's Avatar
Mine would not come close to hooking with 15 in the bias tires. 9 or 10 for mine.
