Old 01-01-2015, 10:57 AM   #11
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Pistons
Depends on the piston. A lot of piston configurations so not lend themselves to equal balance around the centerline of the pin. For example, BBC 396 high compression piston is unbalanced no matter what you do that is reasonable. You can add a lot of weight to the flat side of the piston to balance it, but is the extra overall weight infringing on the advnatge of minimum reciprocating weight? You can offset the pin, but it will take .150" to .210" offset to acheive balance.
Note: The above numbers were calculated using minimum weight Stock Eliminator pistons. You numbers will vary according to your restrictions.
When I built the engine for the Corvette (SS) I worked to achieve a better balance relative to the pin centerline. Did it help? Who knows?!? A-B-A was not attempted, it just sounded good and trick to converse about in techno-savvy circles.
I have seen pistons out of a very fast 283 SS engine that had the pin offset by .090"
Old 01-01-2015, 12:14 PM   #12
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: Pistons
Dwight would the off set be to right or to the center?
Old 01-01-2015, 03:46 PM   #13
Dwight Southerland
Default Re: Pistons
Old 01-01-2015, 05:14 PM   #14
Billy Nees
Liked 7,854 Times in 1,750 Posts
Default Re: Pistons
Assuming that we are looking at the front of the engine in your picture, then on a V8 engine the drivers side pistons would be offset toward the intake side of the engine and the passenger side pistons would be offset toward the exhaust.
Billy Nees 1188 STK, SS
Old 01-01-2015, 08:20 PM   #15
Jim Hanig
Default Re: Pistons
That's what I thought, thanks.
Old 01-02-2015, 11:09 AM   #16
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Pistons
people use to turn mopar piston around backwards in old days was supposed to make them faster, the diagram posted is for quieter operation,isn't offset the opposite for power?
I would guess the taller the compression height of the piston,the more difference this would make?
MikeTaylor 3601
Old 01-02-2015, 12:21 PM   #17
Ed Wright
Ed Wright's Avatar
Default Re: Pistons
MikeTaylor 3601
Back in the 1960s "reverse offset" was the hot setup for Jr. Stockers. LOL
Ed Wright 4156 SS/JA
Old 01-02-2015, 12:41 PM   #18
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Pistons
Here is a link to JE's new line of asymmetrical pistons that are built offset with attaching article and video..
Most are import applications but you get the point.
http://www.jepistons.com/Articles/10...d-Pistons.aspx
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 01-02-2015, 04:52 PM   #19
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: Pistons
Anyone care to put a HP gain by doing this?
Old 01-02-2015, 11:10 PM   #20
FED 387
Liked 334 Times in 181 Posts
Default Re: Pistons
HP Minimal---- if anything---RPM capabilities / rate of acceleration probably more due to to lighter piston weight but HP negligible
