Old 01-07-2015, 06:58 PM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Balancing Racing Slicks
Why do most rear slicks get bubble balanced ? Is there a problem spin balancing slicks ?
Old 01-07-2015, 07:32 PM   #2
supergas4
Liked 6 Times in 5 Posts
Default Re: Balancing Racing Slicks
think about it.soft sidewall
supergas4 is offline   Reply With Quote
Old 01-07-2015, 08:54 PM   #3
Ed Wright
Ed Wright's Avatar
A friend spin balances mine. Quicker & cheaper to bubble balance at the track.
Ed Wright 4156 SS/JA
Old 01-07-2015, 10:42 PM   #4
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
I spin balance never noticed any issues on track with vibration. Always did radials maybe bias tires have issues?
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 01-08-2015, 12:35 AM   #5
ss3011
ss3011's Avatar
Anyone know how fast a spin balancer spins? I thought about 500 rpm, sounds about right. That would keep a normal street tire (26" diameter) under 60 mph. At 60 mph , even a bias ply drag slick would not grow much.
Old 01-08-2015, 08:24 AM   #6
Ed Wright
Ed Wright's Avatar
You will still find an imbalance you won't find with a bubble balancer. Split your weicght too needs four ounces? Put two front side, two back side.
Old 01-08-2015, 10:34 AM   #7
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
That's the way I learned back in the early 70s. I use 4 weights, 2 on each side, bringing them closer or further apart as needed. I still use my old Coats 10/10 and bubble ballance for slicks and trailer tires.
Old 01-08-2015, 08:51 PM   #8
fordteacherguy
Liked 160 Times in 51 Posts
There is a lot more than balance to fix shakes in tires. Technology has come a long way in tire balancing and rim/tire run out matching. Here is a video from Hunter engineering demonstrating their Road Force Balancer. Note ...this is old technology...we have been road forcing tires for over 10 years to fix non-balance tire shake. I road force all of my slicks and have to re-index most at least once due to their concentricity is not near what a OEM tire has and drag slicks undergo side wall damage from launching that can show up in a road force test but not be a balance issue.
Enjoy! Learn something new!
http://www.bing.com/videos/search?q=...9C2AC5FD52B319
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 01-08-2015, 11:09 PM   #9
Don Anderson
Liked 25 Times in 9 Posts
Talking Re: Balancing Racing Slicks
Thanks for sharing this video Brian !!
Don Anderson
M/S #5891
Don Anderson is offline   Reply With Quote
Old 01-09-2015, 01:56 PM   #10
CMcAllister
Liked 920 Times in 259 Posts
Not all spin balancers are high speed. I have used a Snap-On branded machine with good results. Not sure who actually makes it. I've also used the old Snap-On machine that you spun up by hand with good results. I remember seeing that little machine sitting around in a lot of pro pits years ago.
