Old 01-19-2015, 08:56 PM   #1
L79racer
L79racer's Avatar
Default drive shaft sensor 12 bolt rear?
I need to hook up a sensor and magnets on my 12 bolt rear. Will a collar fit? There isnt much room on the rear yoke as a 9" ford has. Looking for ideas maybe a couple of pictures. Thanks.
Vinny
L79racer is offline   Reply With Quote
Old 01-19-2015, 09:58 PM   #2
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: drive shaft sensor 12 bolt rear?
There's room if you use a aftermarket pinion yoke. I have a strange yoke on my 12 bolt and the collar that I used from racepak fit; but it doesn't have a whole lot of clearance. I have about 50 thousands to spare and that;s it. One thing I had to do was open up the collar as it was too small for the yoke. Hope tis helps. Bill.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 01-19-2015, 10:12 PM   #3
MR DERBY CITY
Liked 7,965 Times in 1,524 Posts
Default Re: drive shaft sensor 12 bolt rear?
Do yourself a favor and put it on the front , it is a whole lot more accessible.M.J
Old 01-19-2015, 10:23 PM   #4
L79racer
L79racer's Avatar
Bill, I have an aftermarket moser yoke. Its very tight. How did you mount the bracket to the housing? I have even less room on the front.
Old 01-20-2015, 12:14 AM   #5
FED 387
Liked 333 Times in 180 Posts
use the set up from a 9 inch Ford housing--- find a convienent place to install the pick up holder---drill and tap a 5/16 hole in the 12 bolt housing to mount the pick up holder install the ring and set the air gap on the pick up -- when you are finished with the whole thing it will look somewhat like a MSD crank trigger set up --FED 387
Old 01-20-2015, 09:30 AM   #6
Rsmith38
Liked 28 Times in 15 Posts
On my dana 44 I drilled 2 1/8" holes in the web and mounted an aluminum bracket to hold the pickup.
Rsmith38 is offline   Reply With Quote
Old 01-20-2015, 12:03 PM   #7
Dion Hildebrandt
Dion Hildebrandt's Avatar
I have a MW rear yoke and a computech 9" collar on it, made a bracket for the pickup off one of the webs on the center section. I previously had the collar on my OEM yoke I just had to take off the seal shield and round out the square area.
computech has 2 sizes of collars and I cant recall 100% but I think I have the larger diameter on my yoke.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 01-20-2015, 12:48 PM   #8
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
I had Simpson machine a yoke with all the clearances so I could use the Racepak collar. As others have done, I made an aluminum mount for the pickup and bolted it to the lower webbing. I also have some adjustability so the pickup is square to the collar magnets. Still have the template I think.
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 01-20-2015, 05:20 PM   #9
L79racer
L79racer's Avatar
Thanks for the replies guys. I should have no problem mounting the collar then.
Old 01-22-2015, 06:28 PM   #10
SST159
Liked 20 Times in 16 Posts
I have a Racepak collar for sale that fits the 12 bolt.
Worked for me for several years on my 12 bolt.
Fits on the dust shield.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
